K&O 1381
Discussion in '400-Day & Atmos' started by Dave T, May 28, 2020.
  1. Dave T
    Dave T Registered User
    Dec 8, 2011
    3,031
    100
    retired
    NC
    I reluctantly agreed to look at this clock for a friend.
    So, I've had it completely apart, cleaned everything including the mainspring, installed a new .0023 spring and it still won't run!
    It will run for a few minutes until the momentum runs out and then zilch.
    What now? Besides throwing it out the back window!
  2. Dave T
    Dec 8, 2011
    3,031
    100
    retired
    NC
  3. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    3,591
    135
    Aerospace Engineer (Ret.)
    San Antonio, TX
    When you move the anchor pin back and forth, do you get the sense that the escape wheel moves strongly? How do the locks and drops look? Any friction anywhere? Does the clock run without the motion works in place?
    Kurt
  4. Dave T
    Dec 8, 2011
    3,031
    100
    retired
    NC
    Thanks Kurt, I'll try to answer your questions.
    When I start it manually, I can see the escape wheel releasing quickly with each beat. Looks good to me.
    Haven't looked at the locks and drops, and it's been a long time since I worked on an anniversary clock, so not sure how to check that. Reckon I'll have to get out my book and study it.
    No friction that I can see.
    Haven't tested with motion works removed, and not sure how I'd do that.
    Looks like I've got my homework cut out for me.
  5. KurtinSA
    Nov 24, 2014
    3,591
    135
    San Antonio, TX
    Definitely check into setting the beat...that could be the problem. Typically, one shouldn't touch the eccentric to adjust the drops...that the peninsula at the top of the back plate. These things left the factory with the eccentric set right. Unless you see evidence of tampering or ham-fisting on the eccentric, it's probably OK. The top block mounts to the saddle...the whole saddle can swivel either way in order to set the beat.
    Kurt
  6. Dave T
    Dec 8, 2011
    3,031
    100
    retired
    NC
    Yep, I know about setting the beat. And this one looks good in that regard. Got fairly equal overswing.
  7. etmb61
    etmb61 Registered User
    Oct 25, 2010
    2,470
    166
    Retired Avionics Technician
    Mascoutah, IL
    Hi Dave,
    So you say this person who asked you to work on a small 400 day clock was a friend? All I can say is don't try adjusting the locks and drops without first trying to throw it out the back window to see if that works.
    Eric
    Dave T likes this.
  8. Wayne A
    Wayne A Registered User
    Sep 24, 2019
    272
    42
    Retired, process controll systems
    If it's not running theres no real over swing yet but you can still see the decaying over swing is equal within a few degrees as a sign the beat is right. Another primary reason they don't run is the fork is too tight on the pin, I try to set 1-2thousandths but some clocks need more due to binding at limits of rotation.
  9. Dave T
    Dec 8, 2011
    3,031
    100
    retired
    NC
    I hate to throw it out today. We've had a lot of rain! And if that didn't fix it I'd have to clean it again. :)
    Wayne, I will take a look at the fork.
  10. tracerjack
    tracerjack Registered User
    Jun 6, 2016
    1,075
    115
    Female
    Lodi, CA
    Did you do a free spin test of the wheels? Whenever I skip that part, I usually have to come back and do it.
  11. Dave T
    Dec 8, 2011
    3,031
    100
    retired
    NC
    Yes, I've learned to do this on all clocks.
  12. tracerjack
    Jun 6, 2016
    1,075
    115
    Female
    Lodi, CA
    Whenever I have one that doesn't run after cleaning, I usually end up watching the fork and escape wheel with magnification for the entire time while it runs, which can be 10 to 20 minutes. Seems a lot longer than that when I'm doing it. It's boring to do, but exposes how the clock is working as its working. On one I discovered the tiniest burr on one pallet. On another I discovered a tiny burr on an escape wheel tooth. But sometimes, I am convinced that when the clock hasn't run in so long, minuscule messing alignments just need a period of adjustment. One nice thing about them is they have very few wheels, so the problem can't hide nearly as long as in a chimer.
  13. clksmyhobby
    clksmyhobby Registered User
    Jan 29, 2011
    58
    Retired electronics/aviation technician
    Central Florida
    Hi Dave,
    Just curious, how far do you wind the clock when you do your running test? I like to try minimum power (couple of turns max) first before I go to full wind-up. This is of course after I make sure the running train minus anchor runs freely. If I can get 48-72 hours at minimum power I go to full power and put it on the shelf.
    I have several of these models and have found these issues causing stoppage:
    1. Burs/rough edges inside the fork
    2. Not enough fork gap
    3. Wound less than 3 full turns - have never put a new main spring in one, but have considered it
    My most recent work is a Seth Thomas Bequest model, now running since March 11 this year.
    Mike
  14. Dave T
    Dec 8, 2011
    3,031
    100
    retired
    NC
    Mike, I first try just a couple of winds also. But on this clock I wound it several times after it wouldn't run.
    Haven't yet looked at it further. But I see a lot of things here in this post to check.
    Hopefully get back at it tomorrow.
  15. Dave T
    Dec 8, 2011
    3,031
    100
    retired
    NC
    Came home from church and decided to tackle that clock. After confirming proper beat, and made a slight adjustment to the fork.
    It's now running well with about 340° rotation.
    Only problem is, the hands don't turn! And the minute hand is square on the arbor but very loose.
  16. tracerjack
    Jun 6, 2016
    1,075
    115
    Female
    Lodi, CA
    Then I would assume you are missing a tension washer, either the football shaped one or a round domed one, or both.
  17. Dave T
    Dec 8, 2011
    3,031
    100
    retired
    NC
    #17 Dave T, May 31, 2020
    Just took the dial off, and I have a flat washer on the front side of the plate. Nothing else. Is that right? And the cannon pinion is loose on the shaft.
    Does the washer provide friction for the cannon pinion? I'm sure I didn't lose it, and I don't have one.
  18. Dave T
    Dec 8, 2011
    3,031
    100
    retired
    NC
    I think I'm in "bidness". I found a dial washer for an Elgin pocket watch. Put that baby on there and the hands are back on the job!
  19. KurtinSA
    Nov 24, 2014
    3,591
    135
    San Antonio, TX
    Here's a picture of my Kundo 1381 that I took apart. Notice the small spring between the cannon pinion and the flat washer. That should provide the tension in order to keep the minute hand in position.
    Kurt
  20. tracerjack
    Jun 6, 2016
    1,075
    115
    Female
    Lodi, CA
    Those little washers and springs too are easy to lose, especially if someone has oiled them. They’ll stick and then fall off when you aren’t looking.
  21. tracerjack
    Jun 6, 2016
    1,075
    115
    Female
    Lodi, CA
    Yes, the washer provides tension for the cannon pinion and in turn for the hands.
  22. clksmyhobby
    Jan 29, 2011
    58
    Central Florida
    Good deal, Dave!
    My clocks with plate 1381 all run solidly once set up. Hope yours works as well.
  23. Dave T
    Dec 8, 2011
    3,031
    100
    retired
    NC
    Thanks for the picture Kevin, I don't have that spring. But the Elgin dial washer works.
    Interesting observation though, my rotation has dropped from about 340° to 270°.
    I can live with that as long as it runs steady.
    I will say, comparatively, this is one of the easier clocks to work on. Except for the locking pendulum. It leaves very little room for attaching the suspension spring and getting it the right length at the same time.
  24. Dave T
    Dec 8, 2011
    3,031
    100
    retired
    NC
    Well, this morning the hands still aren't turning. And the minute hand is still loose with no tension.
    Can anyone point me to a source for this tension spring?
    [​IMG]
  25. KurtinSA
    Nov 24, 2014
    3,591
    135
    San Antonio, TX
    Dave -
    My cannon pinion with the spring actually has a relief on the backside for the spring to rest in. A few years ago, I was noticing that clocks were missing tension washers and I didn't have much to work with in my spares. I called Chris at The Horolovar Store and he said he could put together a small packet of various tension washers, from the round, football, etc. He included a few of the springs. I'd check with him and see what he can do, maybe put together a similar package. I don't seen tension "springs" in the Timesaver catalog.
    Kurt
  26. Dave T
    Dec 8, 2011
    3,031
    100
    retired
    NC
    Thanks Kurt, I'll give them a call. I looked at their site first and don't see what I need there.
    In the meantime, I reckon I can try a few washers and test the tension on the hands. Maybe I can come up with some makeshift alternative.
  27. Dave T
    Dec 8, 2011
    3,031
    100
    retired
    NC
    Looked at the backside of my cannon and it also has the recess for the spring to sit in. So, I made a spring, got the hand tension proper, as near as I can tell.
    Hands are moving, and now we'll see how much overswing I have. I expect it to be reduced.
    Wayne A likes this.
