• Upcoming updates
Just picked up this Japy movement, Date?
Wishiknewmore
Jul 30, 2016
49
England
Hello again
I just picked up this French Japy movement, mainly because it was there!
I have tried to date it myself but my findings suggest that its 1850's but to be honest I think I am wrong, too clean and shiny? It is very clean but unfortunately there is a nasty chip( repaired) in the enamel face.
I am also assuming that the suspension is clamped in between the two brass plates?
Any comments would be appreciated.
Many thanks
Philip
IMG_4686.jpg IMG_4687.jpg IMG_4688.jpg IMG_4689.jpg IMG_4690.jpg IMG_4691.jpg
Reactions: Dave T
Royce
Oct 8, 2018
390
124
71
Houston
Phillip,
According to "Dating French Clocks Using Physical Parts – Suspension, Striking, and Exposition Medaillions" by Scotty Dean, the suspension is
"Vallet Suspension = upper portion of the suspension spring is completely enclosed as two brass halves that slot
and screw together. Appears mid 19th century."
Based on the Medaillion on the movement verses those shown in the aforementioned work, I believe it was won in 1867 but I could be wrong.
Hope this helps a little.
Royce
jmclaugh
Jun 1, 2006
5,807
428
Devon
One source has Japy et Cie, formed in 1854, has having been awarded that medal in 1855 and 67. The same source claims this medal was used from 1855 to around 1888 but other markings have been seen on their movements in that period so determining when these medals were used and for how long appears to be unclear. The other mark on the backplate is most likely that of a finisher who bought in a roulant (unfinished movement) from Japy.
Dave T
Dec 8, 2011
4,421
459
NC
I have a decent case that's been collecting dust for a while now looking for a movement. But the opening is in the 4" range, don't remember exactly.
180,051
1,570,716
54,363
mickri
911
3,090
