Just an Elgin
dcjens
Aug 3, 2020
87
34
This Elgin 18s stem/ lever grade 70 Raymond followed me home today.
It's missing the crown and stem.
I'd like to obtain the part. I've read for hours (likely in the wrong place) and was hoping to get an assist with part numbers and length.
musicguy
Jan 12, 2017
9,244
6,110
New York State
The easiest first answer is buy another 18s American case on ebay
and put that movement in.
Edit: but that's not what you asked. I'm sure someone will try and help.
Rob
dcjens
Aug 3, 2020
87
34
Rob
This case is in decent shape. Any ideas are welcomed. I've perused Ebay a little. Thanks Rob!
viclip
Jul 20, 2018
881
655
93
Can you ID the case from the info found on the inside of the back cover?
And is there a sleeve present inside the pendant (they're threaded in & have what look like 4 slots around their circumference)?
Knowing the above some of the membership can probably tell you which stem &/or sleeve you need or at least direct you accordingly.
Reactions: Randy Beamer
dcjens
Aug 3, 2020
87
34
viclip
Jul 20, 2018
881
655
93
Looks like a Dueber case then.
The sleeve's in place but I'm wondering whether it is damaged, thus allowing the stem/crown to have been pulled all the way out of the pendant. That sleeve can be removed for inspection using an American-made sleeve wrench for pocket watches or, on an ad hoc basis, a small blade screwdriver could be used albeit a bit of shaping may be required.
Hopefully someone here is sufficiently familiar with 18s Dueber cases that they can assist you in sourcing the stem/sleeve/crown components required.
Reactions: dcjens
Rick Hufnagel
Just Rick!
Oct 25, 2018
3,039
4,983
Pittsburgh pa
Unfortunately, I think the best way to find a stem, sleeve and crown is to find someone with a giant pile of them to try. Maybe check with your local NAWCC chapter, try www.Daveswatchparts.com, www.pocketwatchcaserepair.com can get.you fixed up, or hopefully someone may contact you through private messages here.
Purchasing random stems on eBay will usually just fill up drawers. There isn't going to be a replacement part to find that is made for this specific case... Its going to be trial and error with different stems, sleeves and crowns.
Reactions: viclip and musicguy
dcjens
Aug 3, 2020
87
34
[/QUOTE]
Thanks Rick! I happened to have a Hampden 18 and out of my curiosity I tugged on the stem and it popped out. I inserted in the Elgin and was able to wind it up... and it runs.
To narrow down choices measuring the stem I have that worked seems in order yes?
Thank again for links to possibly find one
musicguy
Jan 12, 2017
9,244
6,110
New York State
Finding a stem that will fit the movement is easy, finding one that will match the case
is a different story. As Rick said it will take a pile of stems that you would need to sort through
and a functional sleave as well probably.
Rob
Dave Haynes
Sep 12, 2000
1,462
79
I have a lot of sleeves but the bottles and menu are long gone. If you need help with the sleeve PM me.
D
174,337
1,523,241
52,166
VTC Duane
1,063
2,970
Last page
