Most visitors online was 1990 , on 7 Feb 2022
Certainly not a cheap clock - Winterhalder & Hofmeier were one of the best makers of their time.On first examination it looks like a very economical clock made to sell at a low price
As has already been said, nuts and bolts are used on more modern clocks. Pinned shafts are the older method.Very simple movement and not held together with nuts and bolts.
No, this is how it was made and sold. It is a very nicely carved case, and quite an unusual pattern.Was it all painted black over an oak case?
The case may have been ebonized by the case maker. If yes, then anything you do to remove the ebony finish, means you lose originality.Maybe I should experiment on a small patch of the case black paint to see if it is nice red oak under the paint.
That appears to be a very good movement.Here are a few pictures of the "works'
For what reason do you want to let down the spring? Are you experienced in servicing spring driven clocks?I was wondering if I should invest in a tool to unwind the spring.
I was confused by your first post, I thought you had the second clock, with no ebonizing. Sorry for my misunderstanding.The case may have been ebonized by the case maker. If yes, then anything you do to remove the ebony finish, means you lose originality.
It is a time only movement so that's as simple as you can get and therefore cost less to make and buy. W&H movements were better made than most and hence command a premium, the case is also very well made.Thank you for the greetings. On first examination it looks like a very economical clock made to sell at a low price. Very simple movement and not held together with nuts and bolts. But I am a complete (almost) newby to all this. Was it all painted black over an oak case?
Totally new to servicing spring driven clocks, so will not attempt to do things that I am not sure of, (I hope)The case may have been ebonized by the case maker. If yes, then anything you do to remove the ebony finish, means you lose originality.
The picture you supplied from the auction house is not very good. Please supply clear pictures of the various parts of the case. Perhaps we can determine if your case came from the case maker as ebonized or if it was painted by owner at some point in its life.
Regards.
It is still running and quite accurate. I only cleaned out some old black oil residue and dropped a speck of oil on the bits that matter, allthough I did see oil where it should not be. Thank you. I will try to remove some dust that has accumulated on the case since 1880,142 year ago...Glad to hear it is running though it looks like it could do with a service, it should run for 8 days, maybe more.
