... The number on this case is 13244657. ...
Hi Allan:
Its a very nice watch!
I think that the case serial number is 1324657, not is 1324
4657.
... The movement. 19 Ruby jewels. (Not too clear on the photograph). Serial number 2041129 ...
Also, I can make out the marking "19 Jewels" but I can't find the word "Ruby". This is significant because watch companies usually reserved the "Ruby Jewel" marking for higher grade movements.
... PS; I know someone will say the serial number should be saying it should be 2021129, which would describe this watch, it has to be a mistake,
but 2041129 is on the watch, which makes it a Bunn Special, which it is not.
Note; movement serial number 2,041,129 is obviously not a model 6, 18-size, open-face. 21-jewel Bunn Special movement. Obviously , there is an error in the records.
Serial number 2,0
21,129 is in a run (2,041,001-2,041,500) listed as 12-size movements, Yet Ed and I have the following serial numbers of 16-size Burlington Special movements in our data base that come very close to describing your watch; with the possible exception that they are lever-set:
2,021,195
2,021,301
2,021,496
2,021,686
2,021,736
2,021,813
2,021,870
Your watch appears to be pendant-set; is it? At any rate, this is another error in the records.
By the way 2,041,129 (just added) is the only watch listed in our data base in the range of 2,041,001-2,042,000. So, not only do you have a very nice watch, its an interesting one as well!
