In Steven Conovers book "Chime Clock Repair" this movement is called referred to as Junghans B-10 chime and strike model. The clock I have asked questions about model, year, etc. on a thread (https://mb.nawcc.org/showthread.php?44808-Post-your-JUNGHANS-clocks-here); but, thought here I might get this question sooner than later.
The springs are not original. This I know because they don't fit the barrels correctly (much too narrow) and they don't seem to be strong enough. It appears that someone used kitchen clock springs in a past repair.
My question is: What were the original springs' width, strength, and length?
I could do the calculations based on the barrel diameter, arbor diameter… and vary the strength (thickness) and find something that might work. I would like to start with knowing what the springs SHOULD BE.
Thanks for your help and inputs.
