• Upcoming updates
Junghans auxiliary winding mechanism
Dans Clocks
Dec 2, 2020
30
12
65
Prunedale, Ca
Hi everyone
I am working on a Junghans clock that the click wheel on time train had lifted and allowed the click to go under it.
Was there a spacer originally to prevent this from happening?
My plan is to make a brass thick washer to prevent this from happening again.
Clock has been worked on by others in the past
Chime side needs one also.
Chime train had lots of problems spring barrel had a bad tooth replacement, C2 had bent teeth, C3 had bent pinions.
Strike side had a spring arbor hook broken off
Dan
attached are photos DSCN1951.JPG DSCN1952.JPG DSCN1954.JPG DSCN1956.JPG DSCN1957.JPG
wow
Jun 24, 2008
7,106
1,337
77
Pineville, La. (central La.)
Dan, I’ve worked on several of these and I think you are right about the spacer. I don’t remember exactly what it looks like. Others may have one and can post a photo of the spacer.
Dans Clocks
Dec 2, 2020
30
12
65
Prunedale, Ca
Hi WOW
Thanks for the reply.
After 2 cleanings on chime side you can slightly see discoloration where there may have been one.
Dan
tracerjack
Jun 6, 2016
2,840
661
Lodi, CA
Yes, there are spacers.
E9015E58-F578-49FC-9914-63ABDC18542F.jpeg 0636F456-F38B-4A2E-9370-7C2FB06A58D5.jpeg
If you need measurements, I’ll get it out. It’s a loose movement packed away in a box.
tracerjack
Jun 6, 2016
2,840
661
Lodi, CA
That looks good. I don't know if your movement is exactly the same as mine, but there is a rim or a small spacer on the intermediate wheel of the time train as well as on the main arbors.
tracerjack
Jun 6, 2016
2,840
661
Lodi, CA
That's a lovely case you have with the viewing glass. These movements seem to have consistent trouble on the chime train. But, I guess after nearly 100 years, I should expect trouble somewhere. On two of mine, the C2 had broken leaves. Fortunately, the S2 is identical, so was able to get one good movement out of two. Once running, it is a great movement, and I particularly love how it looks. Hope yours is back together soon.
Old Rivers
Oct 4, 2016
163
32
North Texas
One of the wheels on this movement has ratchet teeth which look typical. The other wheel's teeth more closely resemble those of a conventional wheel, and the click's tooth form doesn't seem to match. Unusual in my admittedly limited experience.
Bill
wow
Jun 24, 2008
7,106
1,337
77
Bill
Bill, I’ve worked on several of these and they all are made that way. I’ve wondered why on every one.
Reactions: Old Rivers
tracerjack
Jun 6, 2016
2,840
661
Lodi, CA
Me too. But it works. This one has me scratching my head as well. It’s a GB, but the same type of assisted ratcheting system. The teeth are all angled, yet I can’t believe if this was from a catastrophic failure, that they would all be bent so uniformly, with none broken or marred. It works just fine, too.
Dans Clocks
Dec 2, 2020
30
12
65
Prunedale, Ca
Thanks for all the replies
It is a nice case, wish it was mine but it is a customers.
I only noticed it needed spacers as time click was under click wheel and was unable to wind,
I think chime train issues were caused by same issue.
It shows evidence of at least 2 different people working on it.
Have it back together and running outside of case,
Thanks again
Dan
180,027
1,570,426
54,350
Davido
911
3,090
