I also noticed a similar clock on eBay no. 23115 had a suspension guard. My clock at 24517, 1402 clocks later, never had one nor does it have Germany on back plate.
No, there is a collar at the base of the pin that allows its rotation, if I remember correctly. I am not where I can get to it to check. I definitely don't see that on yours.View attachment 462506 My photo shows anchor and pin. I cannot move pin and fear too much force will cause more damage. Is your anchor like this whatgoesaround?
I have seen some eccentrics in pretty bad shape with the slot rounded off which I assume is your problem. First I would take a very sharp scribe or other sharp tool and try to dig out any brass that has been displaced and would prevent a tool from fitting the slot perfectly. An offset screwdriver offers the best leverage in turning these but spend some time filing and dressing the blade for a perfect fit. Most of the offset screwdrivers I have have a hollow ground blade which should work the best in this situation.I am thinking to try and file a sharper groove into the nut? Any suggestions or warnings?
The clock has been partially dismantled for quite a while. I removed the escapement to run the movement to check on mainspring integrity. The pin on the arbor is canted slightly to the right viewed from the rear of the clockHi Les B, is the anchor on your clock with a collar for the pin to turn left to right like all the others or is the pin coming straight out from the arbor?
I never heard back from you, Les.I am away on holiday and only have limited access to email and internet, back on the 12th
Your picture is sharp when you click on it for an enlarged view.Don’t know why photo is not sharp. Original is.
