JUBA Bim-Bam
Discussion in 'Clock Repair' started by MuensterMann, Aug 10, 2019.
  1. MuensterMann
    MuensterMann Registered User
    Mar 23, 2008
    1,106
    10
    Does anyone know off-hand on a German JUBA bim-bam that has one chime rod for _____ and 3 chime rods for _____, if the bim is on the 1 or the 3? When I got it, the bim one on the single rod followed by the 3-chime chord. I am not sure if it is correct. What is the usual when dealing with 1 and 3 rods, one for bim and the other for bam? Thanks!
  2. wow
    wow Registered User
    Jun 24, 2008
    3,277
    115
    Retired Music Minister
    Pineville, La. (central La.)
    Usually the first strike is on the higher pitched single rod and the second strike is on the other three which are tuned to a lower pitched chord.
  3. MuensterMann
    Mar 23, 2008
    1,106
    10
    Thanks Will, that is what I thought. The bim was so light, and the bam chord was so loud, that it made me pause. What made it worse was that the bam was slow in coming! Now that it is cleaned and lubed, hopefully faster and better sounding!
  4. MuensterMann
    Mar 23, 2008
    1,106
    10
    Another thing about this movement is that one side of the barrel arbor sits in a hole in the back plate, but the front only sits in the square of the ratchet disk/wheel. Thus, it inherently has a wobble to it. Has anyone seen this and is it an issue?
  5. MuensterMann
    Mar 23, 2008
    1,106
    10
    Here is an image to show what I mean.
  6. wow
    wow Registered User
    Jun 24, 2008
    3,277
    115
    That slot is there only so you can remove the spring arbor. The arbor should run on a round section at the inner end of the slot. Remove the click and check it.
  7. Uhralt
    Uhralt Registered User
    2,977
    244
    That's how they are usually made.
  8. MuensterMann
    Mar 23, 2008
    1,106
    10
    Are you saying that there is a round something on the inside portion of the plate? I am not sure there is. If the arbor went through something round, then how would you get it out the slot (unless the arbor comes off like a Hermle movement)? I don't have the movement in front of me now, so I cannot check for sure.
  9. wow
    wow Registered User
    Jun 24, 2008
    3,277
    115
    The arbor has a round spot that rides in the plate. There is a square section on the arbor next to that round section. When you remove the click, you can pull up on the arbor and slide the arbor and barrell out to the side. The arbor remains in the barrell and is removed by opening the barrell like old German movement barrels.
  10. MuensterMann
    Mar 23, 2008
    1,106
    10
    Is there anything there to keep the barrel from wobbling? There is a slight wobble that does affect the overall power. Is this just the design and nothing to do about it?
  11. wow
    wow Registered User
    Jun 24, 2008
    3,277
    115
    It should not wobble. Take the click off and look at what’s happening.
  12. shutterbug
    39,452
    495
    That round area can wear just like a hole. Just harder to bush :)
  13. Uhralt
    2,977
    244
    The wobble could also be in the barrel or the barrel cap itself. They often wear and need a bushing.
