John Wanamaker Carriage Clock
Discussion in 'Your Newest Clock Acquisition' started by Robert Ryan, Jul 12, 2019.
  1. Robert Ryan
    Robert Ryan Registered User
    Mar 16, 2019
    104
    23
    Maine
    Just arrived, this John Wanamaker Carriage Clock. It actually does run for a while...it is totally filthy. Now I need to get up the nerve to disassemble and clean. It also shows a hairline crack on the dial.
    I have had a couple of carriage clock failures....so hoping this will turn that around. I am guessing it is early 1900s. Any other information welcome.
  2. new2clocks
    new2clocks Registered User
    NAWCC Member Sponsor
    Apr 25, 2005
    2,351
    266
    Pennsylvania
    Bob,
    Your clock was made in France for the John Wanamaker department store in Philadelphia. It was made sometime after 1909.
    I can not determine which French manufacturer made the clock.
    Regards.
  3. Robert Ryan
    Mar 16, 2019
    104
    23
    Maine
    Thanks. I'll attempt to keep my cleaning process updated.
    Of course the most intimidating aspect is removing and re-installing the escapement platform.
    ~B
  4. Uhralt
    Uhralt Registered User
    4,840
    574
    Make sure to let down the mainspring before you remove the platform.
  5. Robert Ryan
    Mar 16, 2019
    104
    23
    Maine
    Yes, thanks, definitely let down the main spring...what is the safest cleaner/solvent for cleaning that dirty platform escapement? I have Zep 505
  6. Burkhard Rasch
    Jun 1, 2007
    4,801
    149
    General-and trauma surgeon
    Twistringen
    the platform has a cylinder escapement,different from the modern anchor.If You handle a cylinder the first time,read first so that You know what You´re doing.If broken they are hard to replace.Good luck with this nice clock!
    Burkhard
  7. Robert Ryan
    Mar 16, 2019
    104
    23
    Maine
    So it's not just a question of removing the screws, lifting the platform out and when cleaned, re-installing with the screws, etc....:???:? Could you steer me to an article, etc as a reference? Thank you.
    ~B
  8. Burkhard Rasch
    Jun 1, 2007
    4,801
    149
    Twistringen
    servicing a platform correctly is more watch work than clock work , especially with a cylinder escapement. It needs to be taken appart,cleaned and oiled. I´d give it to a professional watchmaker to do the job.
    For reading look for a watchmaker´s book on escapements or search "cylinder escapement" on this forum.
    Burkhard
  9. Robert Ryan
    Mar 16, 2019
    104
    23
    Maine
    Understand....the operation, as you suggest, is clearly beyond my skillset. I will do my research.
    Even in its current condition, the clock has been running for several hours....we shall see.
    ~B
  10. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    4,720
    128
    Devon
    Your clock was made by Couaillet in Saint-Nicolas-d'Aliermont, one of the largest producers of French carriage clocks who also made semi-finished movements for others. It looks to be an Obis case which was the most modest, cheapest and most commonly seen style.
  11. Robert Ryan
    Mar 16, 2019
    104
    23
    Maine
    Thank you for this information....what were the clues? There is a small component number 79 on certain parts. I have disassembled and cleaned the movement ...except the platform, for obvious reasons....and it has been running fine for over 24 hours. Now cleaning the case. It is plain as you noted....but I get my brass addiction soothed nonetheless. I'll post pics when done.
    ~B
  12. Uhralt
    4,840
    574
    If you remove the glass panels for polishing the case make notes which panel goes where and what is the upside. Often these panels fit only well in their original places.
  13. Robert Ryan
    Mar 16, 2019
    104
    23
    Maine
    Excellent advice...you have correctly percieved my rookie status.
    ~Bob
  14. Robert Ryan
    Mar 16, 2019
    104
    23
    Maine
    This clock was totally immersive....and thanks for the help and information. Seems to be keeping good time...curious to see how long it will run before the next wind.
  15. Uhralt
    4,840
    574
    If the movement is in good condition it will run for at least 8 days, maybe 10.
  16. Robert Ryan
    Mar 16, 2019
    104
    23
    Maine
    I'll report back.....as I said I stayed away from the platform escapement.....but all seems fine at the moment. I have had two other carriage clock failures. One in particular ran fine but gained about a half hour or more in 12 hours. There was a missing tooth on the escape wheel...go figure.
  17. Uhralt
    4,840
    574
    Yes, this will speed up things considerably. You should also hear an uneven ticking.
  18. Robert Ryan
    Mar 16, 2019
    104
    23
    Maine
    Yes, I didn't notice it at first....now I am sorting out what to do. And I am learning about the lack of interchangeable parts of carriage clocks....another rookie lesson. Not that an expensive education ...but an education in any event. Which is why I left this platform untouched.
  19. jmclaugh
    Jun 1, 2006
    4,720
    128
    Devon
    It looks a lot better, nice untarnished brass. The style of the winding arrow indicates the maker. The movement is also called an Obis, they have the dial fitted directly onto the front plate so the motion works are on the inside of the front plate. Unfortunately cylinder platforms are no longer made so hopefully you can find someone who can service it and sort out the missing tooth. If not you could look to find a spare cylinder or a replacement lever platform is an option but nice to keep it original.
  20. Robert Ryan
    Mar 16, 2019
    104
    23
    Maine
    Thanks for your observations. I have purchased a couple of cylinder platforms off of eBay with mixed results....again learning about the lack of interchangeable parts.....but I may have some components if I can successfully replace the wheel with the broken tooth.....but that's down the road a bit. Enjoying the pleasure of the current working clock.
  21. PatH
    PatH Registered User
    NAWCC Fellow NAWCC Member
    Dec 5, 2014
    1,688
    1,177
    Female
    Texas
    Thanks for sharing your clocks and experiences. Who was the maker on the one with the broken tooth?
  22. Robert Ryan
    Mar 16, 2019
    104
    23
    Maine
    I do not know...here are some photos of the clock in question. I will attempt to repair it myself.....professional estimates far exceed its value. The case a glass are in fine shape.
  23. gmorse
    gmorse Registered User
    11,359
    1,632
    Retired from Xerox
    Hi Robert,
    It's important with cylinder escapements that the dimensions of the escape wheel are an exact match with the cylinder; as well as the wheel being the correct diameter, the impulse plane of each tooth has to fit inside the cylinder and the cylinder has to fit in the gap between adjacent teeth, both with only just enough clearance.
    I have seen a tooth broken off this way, because the teeth are quite vulnerable to rough handling, being perched on those thin stalks; if the balance wheel is pulled out carelessly with a tooth still positioned inside it, this is the result.
  24. Robert Ryan
    Mar 16, 2019
    104
    23
    Maine
    I think most likely it will not work....otherwise the clock is in great shape.....so in my way of thinking ...it's worth a try. Our professionals in this part of the world are booking two years out.
    Thanks for the response.
    ~Bob
