Hi Jerry. Yes, maybe I have stretched it a little with the "not too dissimilar" comment - keep in mind that I am an outrageous novice when it comes to the technical side of pocket watch movements. Here are my thoughts and observations for what they are worth.
I am aware of a number of Moncas watch movements with the barrel set-up on top of the barrel bar like this, and in each case the Liverpool label is as in this example. Consistency with the Moncas label does not seem to be a strong point even so. The example below (#16241) has the same barrel set-up but where the label is concerned, whilst Liverpool is in block text again the signature is simply 'Moncas' in script. This is, of course, a much later movement and has a Massey type III detached lever (all my other movements have a type II). Actually, my movement #7783 is much more like the movements you show (although I don't have a picture of that one to share as yet).
The oversprung balance wheel and applied regulator scale on this movement, do seem to be fairly unique from my research so far. However, taken with the high level of jewelling, screws in the balance rim, and rather neat stopwatch feature, I am guessing that this movement came from a high end gold cased watch (the movement I mentioned in my earlier post, from a gold watch that has recently been broken down, has some of these same features). It has been suggested to me that the style applied to #7225 was popular with customers in London and may have been requested specifically by a London customer. Do you or others on the forum have thoughts on that? John was far from averse to making custom and one-off pieces (I suggest).
I do suspect that, from the technical point of view, my paper will raise more questions than it answers and would love to receive your thoughts on it when it is published. For all sorts of reasons, I find John Moncas a truly fascinating individual and the wide variety of his watch movements bear testament to that mind (I feel).
