John CROSS, London single roller fusee movement #32130 with Pennington 'T' balance
Discussion in 'European & Other Pocket Watches' started by John Matthews, Apr 16, 2019.
  1. John Matthews
    John Matthews Registered User
    Sep 22, 2015
    2,039
    861
    Retired Systems Architect
    France
    This John Cross single roller, with its Pennington 'T' balance, dates from ~1825 and is similar to that discussed in the post started by Ray here.
    The standard reference for Pennington balances is the paper by Vaudrey Mercer in Antiquarian Horology of Spring 1981. In the September 2013 issue of the same publication, A D Stewart published a history of the firm and their chronometers. The firm commenced with Robert Pennington. Born in Kendal he was working in London from ~1777. After his death in 1813, the firm continued under his son Robert and then his grandson John. Stewart describes how when Robert senior started to make chronometers, he began to experiment with designs to improve the performance of the compensated balance. His designs included the provision of tapped holes in the rim to receive compensation screws where required, rather than achieving adjustment by sliding weights as used in the Earnshaw balance.
    Mercer describes four types of balance, identified as types 'YCC', 'Double T', Double L' and the 'Screw type'; the latter described as the forerunner of the modern compensated balance. The design of all four types included a means to temporarily secure the free end of the balance while the temperature screws were being adjusted. The 'YCC' type, the most complicated, is thought to be the earliest and I believe the least commonly found. As for the remaining three types, it is believed that he 'Screw' type was the final variant. Unfortunately, many of the surviving examples, have been separated from their cases.
    According to Stewart, all of the four types were developed before the death of Robert senior. He gives examples of the 'YCC', 'T' & 'L' types from the first years of the C19th and indicates that the 'screw' type appeared ~1810. He also asserts that the 'Double L' became 'so common as to constitute a kind of Pennington trade mark' and this is reflected in the Pennington made watches from 1810 to 1815 in David Penney's archive. A Barrauds chronometer with a Pennington balance of the 'Double L' type from ~1815 is also known.
    After Robert senior's death, the younger Robert ran the business but did not, according to Stewart, innovate the balance designs of his father, However, his sons James and John did attempt modifications, but without notable success. John exhibited a design in 1851 that attempted to cure the middle temperature error, but it was too complicated for general use.
    John Cross is known to have been one of the early adopters of the Pennington balance and it may be that Pennington firm made the balances for Cross. While this is possible, I think it may be significant that John Cross examples, known to me, use the 'Double T' design rather that the 'Double L' design that Stewart describes as that favoured by Pennington. David Penney also identifies a movement that he believes was made for Charles Hill by John Cross, with the 'Double T' balance.
    This movement, #32130 has a particularly interesting 18ct gold dial, which is not only partially hallmarked, there is no date letter, but also carries the initials of the dial maker, viz.'FH' believed to be Frederick Humbert, a gold case maker of Bloomsbury.
    The cap also carries a makers mark 'RE' frequently found on London caps from the 1820's. (I still have not been able to find any candidates to match these initials).
    The size 15 movement does not carry any makers marks but is jewelled to the third with cap jewels on the balance and the lever.
    Unfortunately, it is a non-runner. The balance pivot shows signs of having been broken for some time. There is also evidence of rather crude removal of material from the underside of one of the affixes.
    Apart from that and the absence of hands, the movement is in good order, with a particularly well crafted small rack type counterpoise to the lever.
    John
  2. gmorse
    gmorse Registered User
    10,530
    1,225
    Retired from Xerox
    Hi John,
    Yes, it's a pity someone's been hacking about with this rather uncommon balance.
    The other affix, (green), has been molested as well, the blue screw is different from its mates, the red screw has been shortened and the screw opposite the blue appears to be too far in. If it poises even statically I'd be surprised.
    Keith R... and Omexa like this.
  3. John Matthews
    Sep 22, 2015
    2,039
    861
    France
    Hi Graham - yes, it is molested.
    I think the blue screw is possibly the only one that is of the original length. It appears to me that the red screw was crudely filed in position when the affix was molested - it has the same inclination as the filed portion of the affix.
    The two screws on the other affix appear to me to have had their tip removed with a hack saw!
    There is evidence that when it last worked the balance was catching the underside of the balance cock ...
    Hopefully I can find someone up to the challenge!
    John
    Keith R... likes this.
  4. Omexa
    Omexa Registered User
    Feb 28, 2010
    4,990
    618
    Darwin, Australia
    Hi John, I really like your John Cross movement; pity about the Butchery. I have included a photo of the Balance Adjuster, just in case you need him again? Regards Ray
  5. Omexa
    Feb 28, 2010
    4,990
    618
    Darwin, Australia
    Hi John, a really stunning Dial; I have included photos of my 2 John Cross movements. Regards Ray
  6. Omexa
    Feb 28, 2010
    4,990
    618
    Darwin, Australia
    Oh Shock Horror, I just realized that the "Balance Adjuster", looks like me in my younger days! Regards Ray
  7. John Matthews
    Sep 22, 2015
    2,039
    861
    France
    But Ray it looks to me as if you haven't aged ....
    John
    gmorse and Omexa like this.
  8. Omexa
    Feb 28, 2010
    4,990
    618
    Darwin, Australia
    Hi John, on a more serious note John Cross made some really nice movements; I think that most of them were in Gold Cases; long gone unfortunately, you are very lucky that the Dial did not go the same way. Regards Ray
  9. John Matthews
    Sep 22, 2015
    2,039
    861
    France
    #9 John Matthews, Apr 18, 2019
    Hi Ray - I agree.
    David Penney believes he was a 'real' maker, which he infers, in part, from trade directory entries that describe him as a 'watch and clock wholesaler'. Certainly it appear from the few examples I have found that they have some consistent characteristics and David has used these to ascribe one example of his work, a ~1825 movement for Charles Hill. The features David uses, are the distinctive cock and the 'Double T' balance. I would add to that the 'Savage type' lever counterpoise, the cap jewels on the level, and the cap stamped 'RE'.
    Including your two examples I have found 8 examples of his work, of which only one is cased - this from an Australian dealer, which I will come to shortly as it needs to be considered separately.
    Of the remaining 7, one other (#29346) has pivots set as your #8848, the remainder are jewelled to the 3rd, the lever with cap jewels. Of the balances, your #8848 is the only one that has a solid balance. All the remainder have the 'Double T' balance and a counterpoised lever. That is apart from #9848 which has an early example of Pennington's 'screw type' balance. All those with surviving caps are stamped 'RE'.
    Ray - It looks as if #8848 has the counterpoise lever - can you please confirm.
    Here is a link to the 18ct cased example sold in Australia. As can be seen this is a 3/4 plate with a plain gold(?) balance. The movement is jewelled to the fourth with a capped jewel on the lever. The signature is different, 'John B Cross 70 Cornhill'. The watch was purchased by a member of the forum and there is a brief post here.
    Whether this is the same Cross or possibly his son? I am uncertain. Loomes has an entry for John 'Berryhill' Cross working in Cornhill from 1839-63 and John Cross in Charterhouse Square from 1819-55 (possibly later). Britten has the following ..
    Needs further research.
    Anyone come across his clocks?
    I have only found this ..
    John
  10. Keith R...
    Keith R... Registered User
    Nov 27, 2012
    5,531
    1,970
    Retired Sr. Proj. mgr,
    South
    John, I was telling Ray on the phone, a hallmark on a gold dial is a first for me.
    Thanks for sharing!
    Keith R...
  11. John Matthews
    Sep 22, 2015
    2,039
    861
    France
    Hi Keith - first for me as well.
    David Penney remarked it was unusual and that most gold dials are 14ct, whereas this is 18ct. I only have one other similar dial, also with white and pink gold (Johnson #2296). Just removed the dial and confirmed that it isn't marked. Both are quite thin, the Johnson slightly thicker and I guess it is 14ct.
    John
  12. Omexa
    Feb 28, 2010
    4,990
    618
    Darwin, Australia
    Hi all, here is my nicest very heavy Gold Dial; Josh Johnson, Serial Number 8597. Regards Ray
  13. John Matthews
    Sep 22, 2015
    2,039
    861
    France
    Ray - I thought my #2296 was heavy from its appearance, until I removed it from the brass edge.
    I was surprised how thin it was ...
    John
    PS - did you see my question in post #9 above ...
  14. Omexa
    Feb 28, 2010
    4,990
    618
    Darwin, Australia
    Hi John, I did look for it but I have not found it yet. I will have another look today. I am doing Computer work at the moment to try to make some money. Regards Ray
  15. Omexa
    Feb 28, 2010
    4,990
    618
    Darwin, Australia
    Found it; just an ordinary Lever Escapement. Regards Ray
  16. novicetimekeeper
    Jul 26, 2015
    9,163
    471
    Dorset
    Does a T balance mean a T cross section balance wheel, a double T a rolled I Beam?
  17. John Matthews
    Sep 22, 2015
    2,039
    861
    France
    Hi Nick - here are the diagrams from Mercer's paper that I think are self explanatory ...
    contrasting with the other two common types ...
    Hope that helps ...
    John
  18. John Matthews
    Sep 22, 2015
    2,039
    861
    France
    Thanks Ray - so no counterpoise
    John
  19. Omexa
    Feb 28, 2010
    4,990
    618
    Darwin, Australia
    Hi, John Cross probably made my movement early in his Watchmaking days; I wonder if it was made by the Father? Regards Ray
  20. novicetimekeeper
    Jul 26, 2015
    9,163
    471
    Dorset
    ah that makes more sense, I was getting confused
  21. Keith R...
    Nov 27, 2012
    5,531
    1,970
    South
    I put my Johnson dial up in the Pretty cases thread. It's 18K, but not marked, e-tested.
    Keith R...
  22. MartyR
    MartyR Moderator
    Dec 16, 2008
    10,969
    272
    UK
    My (now) famous Parkinson & Frodsham has a hallmarked dial:
    The maker's mark "WM" (barely visible to the left of the "18" mark" is that of the maker of the case too.
    Keith R..., John Matthews and Omexa like this.
  23. John Matthews
    Sep 22, 2015
    2,039
    861
    France
    Hi Martin,
    Posting your 'infamous #999' and reminding us that the maker's mark 'WM' is both on the dial and the case, is useful in two respects. I believe it was established that the mark was possibly that of William Mean, who is listed as a case maker in Priestley. For the Cross it was the mark of Frederick Humbert, listed In Priestley as a gold case maker in Bloomsbury. From these two instances I think we are fairly safe in inferring that the goldsmiths making gold cases also were making the gold dials and secondly, that the movements with the gold dials were originally housed in gold cases. Not earth-shattering conclusions, but probably worth stating.
    John
  24. MartyR
    MartyR Moderator
    Dec 16, 2008
    10,969
    272
    UK
    Well worth stating, John!
    I guess that "gold dial means gold case" is pretty close to an absolute.
    "Gold casemakers also making gold dials" is now demonstrated to be a reality, but I doubt that it was anything close to common. My instinct says to me that the skills necessary are very different.
  25. gmorse
    10,530
    1,225
    Retired from Xerox
    Hi Martin,
    Yes, I believe that imported fancy dials from Switzerland were probably more common than the home-grown articles.
  26. John Matthews
    Sep 22, 2015
    2,039
    861
    France
    Hi Graham/Martin,
    I read up on gold dials in 'The English Watch' after I purchased the Cross and looked at the illustrated examples. I didn't spot any reference to imported gold dials, viz.
    'A few gold dials, typically with engine-turned centres and numerals on a contrasting ground, either engraved and filled, or, much more frequently, of taised polished gold, were fitted by London makers after about 1810. They became popular with Liverpool makers, especially after about 1820, when frequently they were given vari-coloured gold decoration.' [1775-1825] and 'Gold and silver dials, some engraved, some with applied decoration, always had a following' [1825-1970].​
    So while I can well believe that fancy dials dials may have been imported, I have failed to find any reference to examples of such dials on English made watches in English hallmarked cases.
    Can either of you help me out with the evidence from actual examples of English movements with continental gold dials?
    John
  27. gmorse
    10,530
    1,225
    Retired from Xerox
    Hi John,
    I need to do some digging to find a reference to this, but my impression is that the possible Swiss dials are seen on later and more modest English watches. The dials with pictorial centres showing landscapes and architecture which clearly don't represent anywhere in the UK are what I have in mind. I can't recall seeing this feature on dials which are identifiably English in origin.
  28. John Matthews
    Sep 22, 2015
    2,039
    861
    France
    Hi Graham,
    Your thoughts mirror my thinking for later modest quality English watches and Swiss 'would be English if I can fool you' examples - the higher quality English movements by authentic London & Liverpool makers are more likely to have English made dials.
    I did a very quick search on the forum and found this - which is of the type of dial I had in mind, but on a more typical Liverpool lever with a fictitious signature. I also found this - Swiss dials with some gold work on American movements. This one that I thought was a Coventry movement in a Chester hallmarked case, is more of a puzzler and finally the second watch in this post by Art, which I think might have an English dial, if I understand the comparison he was making.
    John
