Most visitors online was 1990 , on 7 Feb 2022
I actually tried heating with my soldering gun, but had no effect. Thanks for the suggestion.You might try hitting it with a heat gun. It won't get hot enough to damage the metal but should get hot enough to soften the epoxy.
I was afraid of that..... thanks for the reply.From the JB Weld website:
How can I remove J-B Weld after it is fully cured? When fully cured, J-B Weld can only be removed by grinding or filing it off, or by directly heating the product above the 600º maximum temperature threshold.
I tried to get underneath it & could not get anything to go under it anywhere.I would try to pop it off, using a sharp knife or single edge razor blade. Away from the edge of the clock plate would be better.
I thought it was solder when I first looked at it, but was not able to get it to melt, even where it was sticking out from under the plate. I tried using resistant solder technique & that didn't work either. Thanks RC for giving me a reason to finally purchase a mini torch....In the picture, it looks more like solder. JB-Weld is good stuff, but I suspect that if you can get a blade under the brass, you may be able to pop it off. Try to dig it a bit with a knife, if it is solder it should roll up a metal sliver. JB-Weld will come off as dust or chips. Application of flame from a small butane torch will provide the required heat if the brass doesn't pop off.
Yes, what Willie said.
mini torch purchased. band aid removed in 2 seconds! thank you guys. you are the best!In the picture, it looks more like solder. JB-Weld is good stuff, but I suspect that if you can get a blade under the brass, you may be able to pop it off. Try to dig it a bit with a knife, if it is solder it should roll up a metal sliver. JB-Weld will come off as dust or chips. Application of flame from a small butane torch will provide the required heat if the brass doesn't pop off.
Was it solder or JB-Weld? JB-Weld would stink in the flame I think.Thank you guys for leading down the path that allowed me to purchase
I think you are correct. This was just the first time that my soldering guns failed. It took a few trials to get here, but this is solder & I now have a Mini Torch. Thanks everyone for your opinions & advice.It’s probable that your soldering irons just don’t have enough wattage. If you hold it in the butane flame and get it to the melting point of solder and wipe with a cotton rag (cotton won’t melt) the solder should wipe off leaving a smooth silver color. I think JB-Weld burn and stink.
Remember that you're trying to melt some solder applied to a much larger piece of brass which is acting as a heat-sink, cooling the area as fast as you heated it. If it was brazing or silver solder, you'd have had to raise it to red heat to melt it.This was just the first time that my soldering guns failed.
