Jauch 77 Weights
Discussion in 'Clock Repair' started by ticktock, Jan 15, 2012.
  1. ticktock
    ticktock Registered User
    Aug 24, 2004
    700
    What are the weights for the Jauch 77 Grandmother for Time, Strike, and Chime?
    thanks
    tick
  2. The Tick Doc
    The Tick Doc Registered User
    Dec 30, 2007
    204
    full time clock repair
    South east USA
    The last one I worked on all 3 weighs were the same at 7lbs and 4oz. I wedighed them all trying to find the heavyest to place on the chime side. Could not find it they were all the same. Hope this helps...........TTD
  3. ticktock
    Aug 24, 2004
    700
    Sure did help Tick Doc. I need to purchase a weight scale but it did feel like all three weights were the same and that is why I posted this question. Weird that all 3 trains are the same. Thanks.
  4. shutterbug
    41,213
    809
    Pretty common with Jauch GF's. It would sure make things simpler if all of them were like that :D
  5. Scottie-TX
    Scottie-TX Registered User
    Apr 6, 2004
    936
    39
    Mesquite, TX
    Like power consideration from a marketing perspective for many clocks: I suspect weights were made equal to the heaviest one needed so customer wouldn't encounter problems from removing and reinstalling weights.
  6. tlw1344
    tlw1344 Registered User
    Apr 30, 2007
    353
    Central Alabama
    I bought an old kitchen scale from a junk store for $3 and it work just fine. If you replace the Jauch 77 movement with a 451-050 94 cm, the weights are different that the Jauch 77.
  7. mfraser
    mfraser Registered User
    Watch out, some Jauch 77s had 5.4 lb weights on one or more chains. As the clock gradually wears, this may not be enough. Especially if a butcher(ess) did some novice bushing work.
  8. Ed O'Brien
    Ed O'Brien Registered User
    Nov 30, 2009
    556
    Retired, and now full-time clock repairs.
    Winter Park, FL
    As an alternative to a bathroom scale, especially for those of us with a small shop, consider a hanging scale like those used to weight fish. I just hand my weight on it, then when not in use it is out of the way. Weight limits on these small scales makes them inappropriate for the large (30 pound) weights found on some old English clocks.
  9. Jacob22
    Jacob22 Newbie
    Feb 25, 2014
    Some time you see difference in measurement due to adjustment or placement of that scale. So you must place your scale proper for getting accurate measurement. But in some scale you have difference in measurement due to minimum weighting limits of that scale.
  10. Willie X
    Willie X Registered User
    12,209
    751
    I have one that is all original, will check the weights, just curious. I have sawed off lots of Jauch weights to make them somewhere between 4.7 to 5 pounds, for Hermle conversions. I lighten them mainly because the Hermle will strike a little quick, and most of the clocks that have J 77 movements also have a very narrow case. They don't need any 'extra' over-swing.
  11. Willie X
    12,209
    751
    Yep, mine are all the same, but 6 pounds each. I'm not surprised, I've seen marked differences in same movement weights from many companies.
