Japy Frere clock pendulum suspension
vernb
Mar 19, 2002
13
What material should be used for pendulum suspension on the Japy Freres (Medaille DOR #1619). The suspension post has two holes which currently has fishing-line through the holes establishing a loop below the post for attaching the pendulum. The pendulum has a hook on the top for attaching to the loop. There is also a wind arbor which holds both ends of the lines for raising or lowering the loop (and pendulum). The system resembles a cuckoo clock pendulum arrangement but is adjustable. First, is how the system really works? And then, Where can I learn about this system and the material used in it.
Thanks Vern
vernb
Mar 19, 2002
13
Thanks Vern
LaBounty
NAWCC Life Member
Aug 29, 2002
3,448
56
Mitchell, NE
www.abouttime-clockmaking.com
Hi Vern-
You will need some pure silk thread to use as a suspension. It may be a special order from a fabric store, like mine was, but what I use is a 6/20 (.005"). I'm not sure what the numbers 6/20 mean but that's what is on the spool. It can be doubled up if you feel what you have is too slender. Silk thread was used because it didn't stretch. A good reference for this type of movement is Thorpe's "The French Marble Clock". It shows pictures of how the silk is threaded through the holes and then attached to the rate adjuster.
Hope that helps!
Reactions: Curtis Brown
vernb
Mar 19, 2002
13
Thanks David, I really appreciate your help!!!
Vern
165,499
1,440,658
86,269
Nacht Kreatur
2,873
