Jahres-Uhr Catalogue query.
Discussion in '400-Day & Atmos' started by Ada, Aug 31, 2017.
  1. Ada
    Ada Registered User
    Aug 15, 2011
    60
    #1 Ada, Aug 31, 2017
    Hi, i have a query regarding a clock i have which is identical to clock No. 274 in the Jahres-Uhr catalogue. i am led to believe the catalogue consists of JUF clocks of various models.
    The problem i have is although it looks identical from the front the movement is made by Hauck and not JUF. The clock appears original and in working order and it even has a bronze suspension wire fitted.
    I wondered whether the movement had been changed in the past so tried to fit a JUF dial of the same period in place of the one it has, but it does not fit the movement and just slops around in the front plate holes which confirms the dial goes with the movement.
    I cleaned the dial before refitting it, apart from that the clock is untouched. I am not sure if the pendulum is JUF as it is solid cast brass which has been machined. It weighs 422grams. It has a serial No 10875.
    Any information would be appreciated as to its origins.
    Adrian.
  2. etmb61
    etmb61 Registered User
    Oct 25, 2010
    1,528
    Mascoutah, IL
    #2 etmb61, Aug 31, 2017
    Hi Adrian,
    I believe your clock is an original with the movement by Hauck. I have found that style with JUF, Keinzle, and Wurth movements as well. Yours has the two screws for the Huber tubular suspension guard still in place. It's possible Hauck provided the movements to Huber. There are many other examples of that.
    Hauck used turned brass discs for their pendulums, JUF and others used a composite with brass shells over steel and lead cores. Your pendulum is the same as pictured with N0. 200 in the catalog, which also has Hauck style base finials, and a dial normally seen with Urania (Huber) branded clocks. Your serial number is from the time period where Hauck was providing movements to Huber as well.
    Your suspension bracket is correct for Hauck before they introduced their gimbal bracket.
    The catalog provides as many questions as answers.
    Nice addition.
    Eric
  3. Ada
    Ada Registered User
    Aug 15, 2011
    60
    Thanks for your reply Eric it is much appreciated. Do you know whether JUF used Hauck movements then or does the catalogue show various makes and models of clock from that time period and not just JUF available to purchase.
    Adrian.
  4. etmb61
    Oct 25, 2010
    1,528
    Mascoutah, IL
    I doubt JUF used Hauck movements. My personal opinion is that the "JUF" catalog is actually a jobbers catalog, or better yet a Huber catalog, and shows a variety of items available by different manufacturers. Huber used Hauck and JUF movements.
    Eric
  5. John Hubby
    Sep 7, 2000
    11,211
    19
    The Woodlands, TX
    I agree with Eric's opinion about the Jahres-Uhr catalog, that it is not a JUF catalog even though a majority of the clocks illustrated were made only by JUF. He brought this up several months back when we were discussing a Würth clock design and noted there are a few clocks in the catalog with the Würth patented "Kronen-Pendel" (pendulum No. 20 in the Repair Guide) that have never been documented to be original with a JUF movement.
    Actually Huber purchased movements and likely some complete clocks from Hauck, JUF, and Kienzle. I've not found any Huber-associated clock made with a Würth or Junghans movement. While Huber clearly purchased movements from Gustav Becker, that was from 1920-23, long after this catalog was published.
    I've been looking since that time at all the models in the catalog and find there are quite a few that were not made by JUF to the best of our knowledge; at least none of these particular models have been documented with JUF movements. There is some confusion introduced by the fact that a large number of models have been found with movements by multiple makers, which we initially concluded was because case-makers could offer their cases to any maker. Many of these in fact have the same model number shown in catalogs, advertisements, and trade publications being sold by various makers. This even includes a number of Grivolas clocks, which would point to those cases being made in France.
    I don't think this is a Huber catalog, because too few of the models have been found with any Huber identification such as their "Urania" trademark, and at the same time there are several models that have been found with only one maker's movements and no obvious connection to Huber.
    Eric is correct that the catalog now raises more questions than answers, and it would appear now that it could be a jobber's catalog although I have to raise the same question Eric did regarding JUF, "whether by JUF or a jobber, why isn't there a company name associated with the catalog?"
    Back to Adrian's clock, it definitely has a Hauck movement, dial, and pendulum and was made in 1906. The fact that four maker's movements have been found with this case can lead to the conclusion that perhaps Huber purchased movements from all four and assembled them with the same case. It also could support the idea that the case maker convinced all four to buy his case. I need to go through my data to see how many of each maker have been identified and then see if that leads to a conclusion. As a by the way, this is (so far) the only Hauck I have documented with this case.
  6. Ada
    Ada Registered User
    Aug 15, 2011
    60
    John, thank you for your comprehensive information. Its good too know my clock is genuine. It is all too easy to come to the wrong conclusion and believe it a marriage of parts when using the Jahres-uhr catalogue as the only source of information!
    There still seems a lot of hidden history and information regarding torsion clocks to be yet uncovered.
    Adrian.
  7. etmb61
    Oct 25, 2010
    1,528
    Mascoutah, IL
    John,
    I have documented a couple of others like this one with Hauck movements. Number 13216 differing by having moon hands and an early Becker base, and 7814 also with moon hands like 13216 but in a 4-glass case. Both were in online sales.
    Eric
Similar Threads - Jahres Catalogue query Forum Date
Latest JUF Harder Patent aquisition for John to catalogue 400-Day & Atmos Jun 6, 2012
jahres-uhr case repair need help 400-Day & Atmos Dec 12, 2010
at last I've found an early Jahres or maybe Huber? 400-Day & Atmos Feb 4, 2008
two more Jahres for the experts to comment on 400-Day & Atmos Jan 25, 2008
jahres no.65668 400-Day & Atmos Jan 19, 2008
