J. Hicks London Aneroid Barometer Help
BobbyPafralides
Jan 7, 2009
74
Illinois
www.beadworldbeads.com
I have an old barometer in need of repair and am having difficulty finding anything, any help on this would be appreciated. It runs on a fusee like chain, which appears to be broken.
gmorse
12,634
2,225
Hi Bobby,
Yes, it seems from the picture that the hole in the end of the connecting rod, (red), has broken through, so there might still be the rivet in the end of the chain, (green). Making a new hole in the rod would be possible but you'd still have to remove the old rivet in the chain before fitting a new one. If the effective length of the rod ends up being shorter, the instrument will need re-calibrating.
Ralph B
Nov 25, 2006
614
Napier, New Zealand
Hold the two ends in line, and solder together.
The solder lump will never move down as far as the little pulley so will be fine.
Then use a barometer app on your phone to re-calibrate by adjusting the screw at the back.
And, yes, I've done this.
Les harland
Apr 10, 2008
1,649
169
Hertfordshire England
Going slightly off topic I looked up Mr Hicks in Loomes Watchmakers and Clockmakers of the World and found:-
Hicks J London Hatton Garden c1870- c1900 Barometers
167,147
1,456,506
87,334
fredericdb
