There's been a lot of discussion about different factors that impact the operation of torsion clocks. I'm working on an experiment to track and log some of those factors to see what shakes loose using available sensors and micro controllers. I actually started this some time ago and got side tracked.
So far I have a setup to record the date, time, temp, atmospheric pressure, and relative humidity. All the environmental stuff.
For the main spring torque I plan on using a load cell attached to a balanced beam on the winding arbor with the click removed. That way as the spring runs down I can record the change over time. (stock photo)
To sense the escapement drops I have a sensitive microphone and amp. So far, so good.
The difficult puzzle is how to sense the pendulum without interfering with it. I'm thinking I need its amplitude and direction but I haven't worked it out yet. I'll be using a disk pendulum clock so I can attach triggers and sensors around the circumference. Just not sure what to use yet.
There's no way to I can think of to record what time the clock says.
Any engineers out there?
Eric
Eric
