Is this ST dated Sep 1952 or Sep 1925?
Discussion in 'General Clock Inquiries' started by Rob Martinez, Jul 16, 2017.
  1. Rob Martinez
    Rob Martinez Registered User
    May 3, 2013
    73
    Got a Seth Thomas Banjo (see attached) the other day. However, I am a bit confused on the date. I understood that ST reversed the last two numbers of the year of manufacturer and put the month behind that inverted year as their date stamp. But that would put this clock as 1925... The problem is the clock has 99% Phillips (cross) head screws that did not reach the commercial market (auto industry actually) with General Motors in cira 1936. Or is this just a 1952 time and strike banjo.... But werent they Talley Industries by then and wouldn't they have had a different label....
    Thanks in advance
    Rob
    [​IMG][​IMG][​IMG][​IMG]
  2. bruce linde
    bruce linde Technical Admin
    1,757
    sept. '52. they reversed the date on the old ones.
  3. Steven Thornberry
    Jan 15, 2004
    17,661
    Although your pictures are not good, the label looks like a fairly standard label for the time period (1952). See below. Seth Thomas became a division of General Time Instruments Corporation (later General Time Corporation) in 1932. In 1970, General Time became a division of Talley Industries. If you do not have a repair/maintenance question, a moderator can move your thread to the Clocks General forum.
    [​IMG]
Similar Threads - dated Forum Date
Requesting Help to Identify "Fleetwood" Chronograph Pocket Watch European & Other Pocket Watches Mar 20, 2017
Trying to date and learn about this Tall Case Clock General Clock Inquiries Mar 8, 2017
Dating a French Lyre General Clock Inquiries Feb 25, 2017
E. Howard #89 date General Clock Inquiries Feb 17, 2017
Urgos Clock Date General Clock Inquiries Feb 9, 2017
