Is there a source for Japy and Freres clock parts; I need a click and click spring
Discussion in 'Clock Repair' started by timepast, Mar 15, 2017.
  1. timepast
    timepast Registered User
    Aug 3, 2006
    409
    Hello. I have a early 1900s French pot lead clock which looks to have the typical Japy and freres time only movement. Movement is stamped Made in France and the numbers 4 and 6 on either side of the winding hole
    I`m missing the clickspring, click and screw for the mainspring. Is there a source or anyone who might sell me these parts? You can PM me. I can have a friend take a pic , pics if you need them. Thanks so much.
  2. shutterbug
    34,325
    Re: Is there a source for Japy and Freres clock parts; I need a click and click spr
    Picks would help a lot. I'm not clear about what you mean by "screw for the mainspring."
  3. JTD
    JTD Registered User
    Sep 27, 2005
    3,943
    19
    I think he means 'clickspring, click and screw'........ for the mainspring [side].
    Just my thought - I may be wrong.
    JTD
  4. JTD
    JTD Registered User
    Sep 27, 2005
    3,943
    19
    You can buy clicks and clicksprings (which come in various shapes and sizes) from the usual material supply houses (Timesavers etc.). You may have to file the click to fit.
    JTD
  5. R&A
    R&A Registered User
    Oct 21, 2008
    3,302
    Or is the rivet for the spring missing from inside the barrel??
  6. timepast
    Aug 3, 2006
    409
    Sorry I meant I`m the screw that hold the click onto the plate, missing the click and thand missing the clickspring. I have to find a friend to take pics and will send them
  7. timepast
    Aug 3, 2006
    409
    I looked at the Timesaver catalog but could not find a match to match the shadow of the click spring that was on there nor do I know the size or shape of the click that was on there. Does anyone have a picture of the front plate of a Japy and freres or know the maker of a Japy look alike stamped Made in France with the numbers 4 and 6 on either side of the the winding arbor. I get you pictures asap.
  8. shutterbug
    34,325
    The click wheel is pretty forgiving. It does not need the same number of teeth as the old one, but should be of the same size in order to insure a good fit between it and the click pawl. It is not uncommon to have to make and/or reshape a click spring. Get something close and modify it to fit.
Similar Threads - source Japy Freres Forum Date
JAPY FRERES CLOCK PARTS Clock Repair Saturday at 6:34 PM
Soldering and heating with hot air Clock Repair Sep 27, 2017
Stateside source for longcase rack spring Clock Repair Aug 14, 2017
Replacement Movement source Clock Repair Aug 1, 2017
Monitor clock chain source? Clock Repair May 3, 2017
