Is there a movement holder device for vienna regulators?
Probox
Oct 27, 2015
241
12
Halifax Canada
I want to monitor the EW/pallet interactions on my vienna regulator movement. I cannot do it while the movement is installed up on the wall in the case. I want to view it out of the case but as you know Vienna's have the pendulum hanging on the back of the case. Has someone come up with a method to run the movement out of the case?
Also, I was wondering if anybody knows where I can purchase an EW tooth straightener? (yes I have pliers but want to be precise)
14,097
1,512
Keystone might still make one.
With practice you can do as good or better with a small pair of round nose pliers.
The tool is better when you have a wheel that is totally craped out though.
As far as a movement holder, I just hold the movement in my hand and apply finger pressure to the 2nd wheel, while moving the crutch back and forth. It's easy enough to clamp the movement in a visen, or on a test horse, if you need to.
46,719
1,913
I rig up an upright piece on my regular test stand to suspend the pendulum from. You just need a post to suspend it from at the right height for the crutch pin to fit. A 1 X 2 inch board and a couple of screws works fine.
wow
Jun 24, 2008
5,176
527
76
Pineville, La. (central La.)
I wish Scottie were still here. All he worked on was Vienna’s. I bet he had a solution. I have a large one in my shop now that I’m having trouble with. I need the whole mechanism including the pendulum out of the case so I can see everything under magnification. This one mounts like GB movements with the four slotted studs. I guess I’ll have to remove the mount bracket and the pendulum hanger from the case and mount them on my wall or a secure board in order to do that.
Surely somebody out there has come up with a better way. Thanks for starting this thread, Probox.
14,097
1,512
That might be the only way. I have a nice size piece of 5/8" plywood, screwed to the wall, for just such an occasion ...
lpbp
NAWCC Star Fellow
NAWCC Life Member
Aug 25, 2000
2,980
I use a movement horse made for floor clocks, I can use it for Viennas, wall clocks and even coo-coo's, you have to use "c" clamps etc., to hold them, never a problem.
wow
Jun 24, 2008
5,176
527
76
Please post a photo. I use one for lots of clocks but never a Vienna. How do you attach the pendulum and suspension set-up?
bruce linde
ADMIN / MODERATOR
8,701
1,315
oakland, ca.
clockhappy.com
this was one of two stands my clock mentor sold me when i first started out. as you can see it will accommodate movements with pendulums hanging behind the movement.
for vienna regulators where the suspension spring hangs from a bracket attached to the inside back of the cabinet i will hang a suspension spring from the forks securing the top of the movement..... (see red line)
bruce linde
ADMIN / MODERATOR
8,701
1,315
oakland, ca.
clockhappy.com
btw... my holder will also hold the entire mounting bracket for a vr.... which means you would have the original/correct suspension block and spring...
bruce linde
ADMIN / MODERATOR
8,701
1,315
oakland, ca.
clockhappy.com
Bruce, my shallow mind cannot figure out how you connect the pendulum. Can you post a photo?
here are a couple of photos.... it's probably best to keep the movement attached to the bracket and just put the entire assembly in the stand, but i've also had success just hanging a pendulum off of a suspension spring hanging by just the top pin... per the photos. the advantage to this method is that you can slide the spring left/right slightly to put in beat. the disadvantage, of course, is that it's not the most stable arrangement... particularly with an inquisitive puppy around who like to nose-bump swinging pendulums
46,719
1,913
That's what I have. Just needs a piece of wood to hang from.
166,304
1,449,000
86,806
Eric O
2,910
