Is it possible to correct a hunters case that opens greater than 90 degrees?
Melvin Mills
Feb 27, 2011
56
Is that something easy to accomplish or is that something
only a professional should attempt?
Kind regards
Mel
Dr. Jon
Dec 14, 2001
6,417
813
New Hampshire
Depends. Look at the hinge and if the tubes are not bent the problem may be a bent hinge pin. You press out the old one, although bent bent this is a bit tricky. Pushing out the pin requires some skill but as much as a hinge replacement. Replace the pin and that may fix it.
If it not that far off leave it balone.
Melvin Mills
Feb 27, 2011
56
Thank you.
If I send the case to a professional, is this something that costs closer to $100 or $$500 to fix?
gmorse
12,390
2,067
Hi topspin,
I've used Adam Phillips here in the UK in the past, and found him a good craftsman, although this quality doesn't come cheap.
165,461
1,440,303
86,241
36Colors
2,873
