Invar Balance marked dial on 19J BWR
watchbob
May 8, 2009
281
324
Spencerville Ohio & Winter Haven Florida
BWR 16s 15,291,024 has Invar balance dial - grade 372 & it doesn't seem correct!
Have 28,436,104 with Invar balance dial - it's hairspring is different !
Thoughts ? - Didn't know when Elgin Started Invar use - 15 mil seems to early
Bob
musicguy
Jan 12, 2017
8,029
4,516
New York State
The 472 21J (1923-1927) is the first(and only) Elgin B.W. Raymond to get the invar with marking on the dial.
There is a Railroaders article by Kent and Ed about it, I will look to see
which one. The 372 did not have one. You have a 472 dial on it.
This is not the typical one that you see, you see many more
without a Montgomery dial.
Rob
Jerry Treiman
Golden Circle
Aug 25, 2000
6,868
3,307
Los Angeles, CA
As mentioned in another thread, an Invar/brass balance wheel will have the cut in the rim further out from the arm than a standard steel/brass balance wheel. My example here is from a Hamilton 922 Masterpiece.
I would think your Elgins with the marked dials should have a similar balance wheel.
musicguy
Jan 12, 2017
8,029
4,516
New York State
KipW
Mar 24, 2015
159
124
Music guy - is/was this dial also used (even as an option) on the Elgin 16s 23j 540? It has an Invar balance according to the literature.
musicguy
Jan 12, 2017
8,029
4,516
New York State
The Elgin 540 (1938-1941) as I understand it never had that marking
on the dial.
Rob
PapaLouies
Apr 14, 2010
1,214
516
musicguy
Jan 12, 2017
8,029
4,516
New York State
musicguy
Jan 12, 2017
8,029
4,516
New York State
It's cut in two places, here is the close up
PS look at all the work someone did on the balanceo_O but it runs perfectly.
I will not change a thing.
Rob
KipW
Mar 24, 2015
159
124
Well, one of mine has one. (Must've been changed by a previous owner or jeweler.) Although otherwise, it's as original as it gets. Wonder if Elgin or shrewd jewelers actually offered it as an option, since it's a really nice Montgomery-type dial. Has anyone ever seen one on another 540?
Reactions: Old rookie
musicguy
Jan 12, 2017
8,029
4,516
New York State
I would say that you have a switched dial(and hands seem short). A very common practice
done by dealers and collectors over the years not knowing or caring if
it was original at that time for the watch.
Rob
168,196
1,466,878
48,160
HIltonD
2,955
