• The NAWCC Museum and Library & Research Center will reopen starting Wednesday, January 6, 2021 as per Governor Wolf's reopening mandate.
International Register Motor Repair
steve102
Sep 23, 2009
14
I'm trying to dismantle an International Register clock motor to replace the supply leads which have broken off flush with the entry grommet. How do I separate the stator assembly from the gear box casing so that I can access the wiring?
steve102
Sep 23, 2009
14
Any clues as to how I can access the internal wiring? I know new motors are available but I would lilke to keep the original if at all possibe.
harold bain
40,851
172
72
Steve, these motors were not built with any thought toward repairing them. They were expected to be a throwaway item, replaced with a new one.
You will have to determine how the factory assembled them, and then figure out how to take them apart. From your picture, it appears they were crimped together.
