I am having problems getting this clock to strike consistently. When the strike mainspring starts to run down after 3 days or so it misses the odd strike (usually the half-hour) so that when the minute hand is at 12 o'clock it strikes the missing half-hour and subsequent strikes are out. Sometime it misses another strike so that it is more in sync, but an hour slow.
What seems to happen is that it goes into warning but the pin in the picture below catches on the lever which should release it - sorry don't know the correct names. When the hour should strike this is released and the half-hour is struck and the perhaps twice in 24 hours the problem is repeated. I am assuming that the count wheel is not perfectly round.
I have been bending the lever up slightly but if I bend it too much it then doesn't stop striking. It seems really hard to get the amount of bending right. Should I have been doing something else? I suppose I could replace the mainspring so that there is more power and it would presumably work OK for longer.
Thanks for having a look.
