Interfering Gears Stop My Clock
Discussion in 'Clock Repair' started by WDHewson, Feb 11, 2015.
  1. WDHewson
    WDHewson Registered User
    Nov 27, 2013
    31
    Chemist
    Ontario, Canada
    Gentlemen:
    I believe the movement I'm working on is a Smiths Enfield from the 1950s, but I'm unsure.
    I've managed to correct a few faults with this seemingly high quality movement, but the gears in the accompanying image are ever so slightly touching and the friction stops the clock. This is the time drive train.
    One gear is on the spring drum, and the other gear is just below the escapement wheel, so it is a very low torque gear. I tried to get a feeler gauge between these two gears and even the 0.0015 inch (yes 0.0015 inch) won't fit.
    The time mainspring drum has a lot of clearance between the drum and the front plate, so something seems amiss here.
    I might be able to shim this whole drum assembly forward toward the front plate with a shim at the rear plate.
    How would you gents recommend I remedy this fine old clock?
    With appreciation....................
  2. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    156
    deceased
    Well, it didn't come from the factory like that. Look for worn bushings in either the barrel or the plates.
  3. dad1891
    dad1891 Registered User
    Feb 28, 2014
    598
    Denver, Colorado
    Any chance that the spring drum arbors were switched during the cleaning process?
  4. Tinker Dwight
    Tinker Dwight Registered User
    13,666
    69
    #4 Tinker Dwight, Feb 11, 2015
    It looks like he is missing the barrel cap.
    There should be a cover over spring. This
    centers the side of the barrel.
    If the end cap is there, the bushing at the center
    is shot. Either replace the bushing or make a
    new end cap.
  5. shutterbug
    43,140
    1,178
    You can buy caps. Get one that's slightly over-sized, and you can cut it down with a lathe fairly easily.
  6. Burkhard Rasch
    Jun 1, 2007
    4,761
    133
    General-and trauma surgeon
    Twistringen
    look at all gears:all wheels seem to be in direct contact with their respective lantern pinions,but there seems tzo be a gap between 3rd wheel and pinion.Could it be that the wheel once loose has been reinstalled too closely to the barrel?In any case:if there is a gap between wheel and pinion You could use it to shift the wheel away from the barrel.
    Just a thought..
    Burkhard
  7. WDHewson
    Nov 27, 2013
    31
    Chemist
    Ontario, Canada
    Many thanks Harold. Much of this Smiths Enfield has been rebushed, and it's not excellent work, but not a travesty either.
    I like this old movement. It runs with a soft shuffle rather than the loose clatter of most clocks.
    I don't give up easily.
  8. WDHewson
    Nov 27, 2013
    31
    Chemist
    Ontario, Canada
    Thanks dad. I would not have thought of that. Both time and chime drums wind CW. By eye, these two drum are identical, but my calipers show the time drum at 0.914 inches wide and the chime drum at 0.992 inches. This difference of 0.078 inches seems to about the difference between their gaps with the back side of the front plate.
    Both drums have covers that are flush with the drum edge, to a few thou.
    But I'll need to disassemble to inspect their arbors. Great suggestion.
  9. WDHewson
    Nov 27, 2013
    31
    Chemist
    Ontario, Canada
    Thanks Tinker. Great suggestion.
    There is an end cap, but I'll direct my attention to the bushing. I've recently wound down the time spring entirely by lifting the recoil completely away from the escapement wheel.
    If I understand your comment well, with the spring relaxed, I should be able manually to wobble the drum around on the worn bushing.
    I've watched this drum carefully when rewinding the completely relaxed drum, and don't recall seeing a wobble. But I need to look again.
    There's a fair amount of wear on the square of the winding arbor, so I this nice old movement has had an insensitive owner at one time, and some novice attention.
    Much thanks for your helpful reply with picture.
  10. WDHewson
    Nov 27, 2013
    31
    Chemist
    Ontario, Canada
    Thanks shutterbug. I do have the lathe at hand if need be.
  11. WDHewson
    Nov 27, 2013
    31
    Chemist
    Ontario, Canada
    Thanks Burkhard. I also noticed that gap between the 3rd wheel and the lantern on the same shaft. If the 3rd wheel's hub can butt against the latern's hub, that'll be sufficient clearance. That third wheel runs very true with no visual wobble, so I don't need much clearance. I suspect that the 3rd wheel is a friction fit on the shaft, and a few minor taps might shift it over.
    Many thanks............
  12. shimmystep
    shimmystep Registered User
    Mar 5, 2012
    4,095
    81
    Cambridge, UK
    You mention it has much re-bushing before now. Perhaps the bushing for the intermediate wheel in the front plate is not flush at the non pinion end, but may be sunk, so causing the issue. and the pinion end bushing may be too proud.
    If these have been re-bushed and this is the issue, you could replace them correctly.
    It only needs fractional clearance of the drum.
  13. WDHewson
    Nov 27, 2013
    31
    Chemist
    Ontario, Canada
    Thanks shimmy. The rebushed locations on this clock do look a little ragged. For the 3rd wheel that's sitting too close to the winding drum, the bushes are not too bad axially, so I think that the 3rd wheel is about where it should be.
    Another clue I've discovered in this situation is that the teeth of the winding drum are not centered on the lantern they engage, but are set much rearward in that lantern toward the backplate.
    This fact, the big gap from the front plate, and the interference with the 3rd wheel makes me believe that this whole winding drum assembly is set reward too much.
    I'll have to get that drum assembly out and figure out a way to locate the drum forward about 2 millimeters.
  14. shimmystep
    Mar 5, 2012
    4,095
    81
    Cambridge, UK
    Apologies, I meant the bushings on the 3rd wheel, not intermediate!
    I'm looking again at the picture of the barrel in the movement. There is a big difference in the distance from the barrel edge to the front plate, from the top of the barrel and the bottom. i think Tinker has probably got it right. The barrel looks far from parallel to the plate with some wind on the spring.
  15. Tinker Dwight
    13,666
    69
    Of course, Shimmystep, it could be camera angle that
    is distorting our perspective. It does look like it
    is not square with the plates but I could imagine it
    is just a perspective issue as well.
    If it isn't perfectly square, it is a bushing issue.
  16. bangster
    bangster Moderator
    19,695
    406
    It sure looks tilted to me.
  17. Tinker Dwight
    13,666
    69
    Me too Bang. Still I've been fooled before.
  18. WDHewson
    Nov 27, 2013
    31
    Chemist
    Ontario, Canada
    Thanks for the continued help guys.
    My camera has a very fish eye lens in the macro mode and it does distort lines away from the center of the image.
    The barrel is parallel with the front plate.
    As an update, I disengaged the escapement recoil, and let her wind down to little or no spring tension. The barrel flops around too much (I believe) and has too much axial play (about 1.5 mm). So I'll need to get this barrel out and do some shimming or turn out a new arbor.
    Stay tuned.
  19. Nicko
    Nicko Registered User
    May 11, 2007
    191
    Australia
    I can just recall having something similar on a Smiths clock. It turned out to be the 2nd wheels on the time and time and strike side being interchanged. Might be worth a quick look.
  20. Tinker Dwight
    13,666
    69
    That is why I mentioned the end cap bushing. They
    often get ignored when lubricationing and can be
    quite warn.
  21. WDHewson
    Nov 27, 2013
    31
    Chemist
    Ontario, Canada
    Thanks tinker.
    Your cover bushing diagnosis nailed it. A correction and the old Smiths Enfield has been shuffling along for many days now.
    I like this movement. High quality and a slick beat adjustment with no crude wire bending.
    With appreciation to all..................
  22. shimmystep
    Mar 5, 2012
    4,095
    81
    Cambridge, UK
    Good news:thumb: Did you rebush the cap?
