Interesting Staartklok movement
oxblood2
Mar 4, 2008
842
85
Here are a few photos of a Staartklok being shipped to add to my collection. Thus one has a “Dutch strike” with stacked bells.
The count arm appears to be a horse , from what can be seen.
EF444C50-2656-421F-9135-03A79F794221.jpeg 0CB34B9F-9F36-4FEE-97EB-6052105DD0C3.jpeg 7E85CD90-5A63-4DC4-82C5-3D5CAD103AD5.jpeg 75EE2290-C847-4627-BE87-E5EFE2C5AB0B.jpeg 3B5A2652-FB9A-4941-BE20-2E3C6004EB19.jpeg A791D875-3AA9-4E88-810F-3B38F90FF855.jpeg B1FAFE12-2D9A-4518-BE56-B9C8973C2969.jpeg
oxblood2
Mar 4, 2008
842
85
Thank you,
It’s hard to date these clocks. I would doubt it no older that mid 19th century.
PatH
Dec 5, 2014
2,879
2,446
Texas
Another amazing clock, oxblood2! What style finials does/should it have? Looking forward to additional pictures when it arrives. Thanks for sharing it with us.
oxblood2
Mar 4, 2008
842
85
Thank you,
This one doesn’t have any finials. When it arrives I’ll look for evidence of a center “chimney”. If it had my options will probably lean toward the trumpeting angels with Atlas. Though others would work.
This forum has always been of great help to me and I’m sure to others. The more info and photos we have, the more help there is for others.
ACE04315-3250-4038-A059-22F3A75CF1F7.jpeg 09764E4F-724E-403B-A0EB-ABEB2D9AFD4F.jpeg
Reactions: Jezster18 and PatH
PatH
Dec 5, 2014
2,879
2,446
Texas
oxblood2
Mar 4, 2008
842
85
The clock arrived today and am very pleased with it. Here are a few photos of the back of the dial. The initials “LEB” are followed by a date either 1894 or 1834. The third number does not have a straight line( like the 1 or the 4) or a single curve for the number “9”. Below the top plate, the line, still curves back under the top loop of that number. Hard to photograph while in place.
FF2E2191-FCDE-4B63-AE7C-05CA9BF5D588.jpeg CA83ACA3-A09C-48B0-9CB5-E13A983EA030.jpeg
oxblood2
Mar 4, 2008
842
85
I now have the dial off and we can see the date. Thoughts? The first initial could be a “T”
oxblood2
Mar 4, 2008
842
85
That is a beautiful clock, love the details. The date looks 100% 1834 to me.
Will
Thank you Will.
There are many features of this clock that will be good to have available for research.
This is my 7th Staartklok and has many attributes that aren’t on my others. As I get farther in it , I’ll post most photos ,for help with the forensic’s.
Reactions: PatH
WIngraham
Apr 19, 2019
294
186
35
They are a fascinating type of clock, very decorative with interesting movements. Every one I see, seems to be a bit different. I will have to seek one out some day.
Looking forward to your progress.
Will
oxblood2
Mar 4, 2008
842
85
Cleaned up the cover of the “tail” of the clock. All the inlay seems to be intact.
The lead ornament for the aperture is interesting, in that the cabinet maker recessed it into the case. I’ve not seen one done that way , as most are just applied to the front.
A1C1F675-6A03-42B2-A7D0-AF40FA13E0B7.jpeg 99C101C6-C7D0-4335-8CC2-99C8F7695FAC.jpeg E8C92285-D9C4-40EA-81C2-E5B55BD7AE61.jpeg 92C82445-3F78-423B-B8BA-48C623DD5527.jpeg
PatH
Dec 5, 2014
2,879
2,446
Texas
Looking good! Very interesting imagery with the rooster at the top and Father Time/Grim Reaper seated with his scythe and hour glass. Have you ever seen this type of imagery on other Staartkloks?
oxblood2
Mar 4, 2008
842
85
This ornament for the aperture is one a several common on Staartkloks . This same one, is on my other inland clock. Interestingly
It has the wise owl at the center bottom.
Reactions: PatH
oxblood2
Mar 4, 2008
842
85
Another very unique feature on this clock, I’ve not seen or read about is a “Starter”.
It allows for the pendulum to be started from outside of the case, without you actually touching the pendulum!
At the bottom of the “tail” is a brass tab that goes through to the inside of the case. With a quick push to the tab, the extension of the tab, moves to the opposite side and the “paddle” pushes the pendulum to swing! 91A7C81F-81EA-4F41-9B0B-CC01E40F40F2.jpeg CEDD2725-AFB1-4BB8-BD5F-6C24E86E589B.jpeg AFDAA4D7-4411-4552-9D88-9BBB067A56FE.jpeg
oxblood2
Mar 4, 2008
842
85
mit allows for the pendulum to be started from outside of the case, with you actually touching the pendulum!
At the bottom of the “tail” is a brass tab that goes through to the inside of the case. With a quick push to the tab, the extension of the tab, moves to the opposite side and the “paddle” pushes the pendulum to swing! View attachment 721371 View attachment 721372 View attachment 721373 View attachment 721373 View attachment 721372 View attachment 721371
oxblood2
Mar 4, 2008
842
85
The dial is held in place with a lower hook and two upper extensions on the top plate, that go through the dial and are held in place with pins. Much like Stoelkloks
C9897603-0554-4458-94F4-4EFBE72A02AB.jpeg 1EFE8FF5-0EEF-47AF-A727-A08B1A06EFDB.jpeg DD0DE2D9-FBF3-4D02-8229-8C12737DCED6.jpeg
Jeremy Woodoff
Jun 30, 2002
4,252
150
Brooklyn
I think 1834. The starter tab is great! I have something similar on a Black Forest box clock that has the pendulum enclosed in a lower box like the staartkloks, but it's a knob on the front that you turn, and a metal rod then engages the bottom of the pendulum and gives it a shove. The pendulum view ornaments are usually stamped brass; the lead ones are less common, another reason that makes me think this is an older clock. Very nice!
Reactions: oxblood2
176,449
1,544,450
53,311
Trikky2
1,064
3,031
