DaveyG
Perhaps I should add to the header "I think".
I was recently shown an 1860/70's English made, full plate fusee driven watch that had been placed with the local watch repairers for overhaul. I was asked what the stampings on the pillar plate meant. I won't bore you with yet another explanation of the markings but to point out that the movement maker's mark is that of John Wycherley, working either in Prescot, Lancashire or, possibly, Birmingham (I neglected to harvest the hall mark data). The name MARLOW is not one that I had seen previously, in fact I don't recall a 'model' identifier being stamped on a pillar plate previously.
When I dropped in again, to the shop, a few days later I was shown the watch after cleaning and a donor watch (from the scrap movement box) that had been used to furnish a replacement centre wheel and escape wheel. This one, clearly the same raw movement design, also stamped MARLOW but by a different movement maker. In this case, probably, William Brown of Ecclestone, Lancashire.
Apart from the fact that it seems that a different coding method for defining the dimensions of the movement was used it seems to be a common design of movement made in different locations. I don't think that this is a feature of the English trade that is well known; I have certainly never witnessed this before.
Any views, opinions or added knowledge would be much appreciated.
Incidentally, John Gabriel Jones of Pwllheli I can not find listed anywhere so is, presumably, a retailer.
