T.Cu
- Sep 26, 2020
- 290
- 53
- 28
- Country
- Region
Hi Everyone, I have a "new" New Haven clock, shown in the photos. Has anyone seen a fast slow assembly like this one? It's new to me.
Can you see the lever showing below the hands? The little lever is steel and has a sheath fitting over the flat pin on the movement, and pulls off with the hands for removing the movement.
When the lever is on, moving it one way or the other raises or lowers the suspension using that "handlebar mustache" shaped cam plate.
It didn't seem to work all that well over the years.The area of the dial around the hand arbor hole in the dial is pretty cracked and chipped from people moving the lever. Also they seem to have kept pushing the lever further towards the dial, because there's not much room for the hands to fit over it yet still be under the glass.
