Installing a round Ansonia movement
Discussion in 'Clock Repair' started by Bill Cann, May 23, 2019.
  1. Bill Cann
    Bill Cann Registered User
    Mar 26, 2019
    30
    Recently finished a round Ansonia Brocot movement and the slate case. The case has round cutouts on front and back. In spite of tightening the mounting screws, the movement slightly rotates when winding and puts the movement out of beat. Is there a "preferred" way of securing the movement? Glues, epoxies, etc seem excessive.
    Thanks, Bill
  2. Uhralt
    Uhralt Registered User
    4,844
    575
    I have been using a large thin O-ring between the dial and the case. Works great and you don't have to over-tighten the mounting screws.
  3. Bruce Alexander
    Sponsor NAWCC Brass Member
    Feb 22, 2010
    6,879
    620
    Double-sided tape can work well also but it is tricky to adjust while rotating the movement into beat. You need to get it set and then slowly tighten the mounting screws while checking to make sure the movement is still in beat. The O-Ring suggested by Uhrait works well, but you also have to be careful not to over-tighten. Fortunately, it doesn't take much to get the O-Ring to hold fast. Good luck with it.
  4. R&A
    R&A Registered User
    Oct 21, 2008
    4,193
    106
    If you don't have it tightened down enough it will move
  5. shutterbug
    43,415
    1,224
    Yep. But I kinda like Uhralt's O ring idea. Takes a little of the stress off the mounting brackets.
  6. R. Croswell
    R. Croswell Registered User
    10,306
    863
    Great idea! I'll have to remember that.
  7. R&A
    R&A Registered User
    Oct 21, 2008
    4,193
    106
    Really and how readily available are these O rings
  8. Uhralt
    4,844
    575
    At hardware stores. I get mine at the local ACE. And, this is completely reversible. I've got the idea when I stripped the thread on one of my French clocks due to over-tightening. This clock got out of beat almost every time when I wound it, so I tightened harder and harder. With the O-ring, no problem anymore.
  9. Willie X
    Willie X Registered User
    12,774
    984
    I use two tiny dots of E-6000 craft adhesive at each side. It's easy enough to remove when necessary and I've never had one slip yet.
    I like the O-ring idea but, in that diameter, it's going to be pretty thick. A thin flat rubber gasket would be much better. And, a flat gasket would stay in place, if it had to be cut to fit. Willie X
  10. R. Croswell
    10,306
    863
    O ring cord is available in various materials including foam and can be cut to length. Never tried to join the stuff but I would expect the foam variety would compress to a pretty thin layer.
  11. Uhralt
    4,844
    575
    I could get pretty thin large O-rings, with a diameter of about 1 mm. I think they are similar to the ones used in some cuckoo clocks to drive the music box. the foam might also work very well if it is easily compressible.
  12. Bruce Alexander
    Feb 22, 2010
    6,879
    620
    I have used an O-Ring once in a Seth Thomas "Tampa". It worked well, but as I mentioned, you have to be careful not to over tighten the mounting ring. I think that the bezel can be made to flex so that it won't snap shut properly. Fortunately one only needs to back off the fasteners to get the bezel fit back to normal.
    I obtained the right size here: The O-Ring Store, We make getting O-Rings easy! but I have some "extras" which may or may not fit when I need another one. I like Willie's suggestion. You don't have to stock different sizes.
  13. shutterbug
    43,415
    1,224
    I would think you would want thin O ring material and make your own. A little super glue will attach the ends firmly, but for this application you probably could use it without connecting the ends. I haven't tried this, but still like the idea ;)
