Ingraham Model 17 clock motor repair/replacement
Discussion in 'Electric Horology' started by bakerb95619, Jan 2, 2010.
  1. bakerb95619
    bakerb95619 Registered User
    Jan 2, 2010
    12
    I have an Ingraham Model 17 clock motor from a 1950's PAM clock that is not working. I've taken the motor apart as far as I know how, to where I can lift the pinion shaft/gear and magnet disc out of the motor. Everything looks clean, and the pinion spins smoothly, but it still doesn't work. Anyone have suggestions, or possibly know where to find a replacement?
    This is the second non-working clock motor that I've been dealing with today. I'm going to submit a separate post for the other one (a Synchron model 610 I43R).
  2. Mike Phelan
    Mike Phelan Registered User
    Dec 17, 2003
    9,836
    15
    West Yorkshire, England
    Have you checked if the coil is open-circuit (a break in it)?
  3. coldwar
    coldwar Registered User
    May 20, 2009
    264
    Repair yours if you can or retrofit, a direct replacement is NLA - For what it's worth I would retro another appropriate type as the Ingraham units are toilets - Best - CW
  4. bakerb95619
    Jan 2, 2010
    12
    Thanks for the reply. I'm not sure how to open the case to check the coil. Here are some (blurry) pictures of the motor:
    http://www.collectorbills.com/Ingraham Model 17 Top.jpg
    http://www.collectorbills.com/Ingraham Model 17 Bottom.jpg
  5. coldwar
    May 20, 2009
    264
    #5 coldwar, Jan 3, 2010
    Hi Bill - What Mike was suggesting is the coil on the motor portion of the mech can 'open' like a burned out incandescent light bulb. That's the first step in triage to determining the possibility of repair for this mech. You can check it easily to determine electrical continuity, a volt-ohm meter, or digital readout multi-meter, or rig up a 7-1/2W C7 night light or Christmas lamp in series with the coil, if it glows dimly powered up, coil is ok, and you can determine how or not to proceed. Best - CW
  6. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    154
    deceased
    Bill, keep in mind that these old motors were not built with any thought of later repairs, and were expected to be disgarded and replaced when they quit working. Some respond to repair efforts better than others.
  7. bakerb95619
    Jan 2, 2010
    12
    I got a bit further in, but it looks like I can't get much further without special tools:
    http://www.collectorbills.com/Ingraham Model 17 Interior.jpg
    The circuit is open, so my guess is one of the thin coil wires is broke.
    Any ideas on where to get a replacement for this motor?
    Thanks for the help!
  8. Mike Phelan
    Dec 17, 2003
    9,836
    15
    It sure is a small motor! If you can get it open, there'll be someone that will be able to rewind the coil.
  9. H.Weiland
    H.Weiland Deceased
    I have a number of new old stock rotors. My list says I have one that might work for you, it is a 17A not just 17. It has a 8 tooth gear on the end of the shaft. If you think it might work for you call me during the evening at 414-463-4681 or drop me a email.
    Henry Weiland
  10. thirtyninechevy
    thirtyninechevy New Member
    Jan 5, 2013
    looking for model 17 replacement where can I find one
