You could, but I rarely find it necessary. The "twist" should break it loose and it should just come off if you pull and twist at the same time. Pliers have a way of slipping and causing collateral damage to the face etc.Follow up. Should I use needle nose pliers to pull and twist? I’ve never done this.
