Ingraham Kitchen winding arbor
BIG D
Mar 2, 2004
488
Memphis Area, TN, USA
Hello all.
I got this Ingraham Kitchen clock in. It needs a good cleaning etc. Pivots and bushes look good. However the strike winding arbor is a bit bodged.
Yes its a bit askew and a bit short.
Any body got one in their parts bin?
Deminsions are:
2.8" overall lenth (of the good one)
1.33" between plates
.18" OD @ bushings
2.8" diamater great wheel.
Thanks for the help, I looked at flea-bay and have a movement bookmarked and may try to call merritts tomorrow.
BIG D
Mar 2, 2004
488
Hello all.
Deminsions are:
.18" OD @ bushings
BIG D
Mar 2, 2004
488
OK another question!
Is this part the same for the kitchen (rear mount) as it is for the mantle (front mount)?
The pics I see... the stem looks longer on the front mount models.
Any one know:???:
44,295
1,347
I've had good success getting those kinds of parts from Norkro. Call the number on the site and talk to Michael. He might have what you need.
buck
Jan 27, 2006
91
I believe that on some t/s clocks, the strike mainspring arbor is shorter than the time side. It depends on how the hole through the plate and count wheel is set up.
BIG D
Mar 2, 2004
488
Thanks Shutterbug,
Buck, I was curious if the front mount arbors are the same length as a back mount arbor. As an aside. all the arbors I have seen were if you will the same height when installed. ie. were in the same depth in relation to the dial.
Thanks for both replies!
Topic related ad experiment
160,838
1,395,478
82,861
Alynn Legal
1,099
2,778
