Ingraham Count Wheel Question
MuseChaser
Feb 5, 2019
382
92
I just cleaned and reassembled an Ingraham for testing. As I'm still learning and inexperienced, and this movement is not exactly like the Ingraham in Conover's Strike book, I could use a little bit more help from any expert willing to chime... or, ahem... "strike"... in.. ;)
As the movement is currently assembled, the hour and 30-minute strikes occur at about x:10 and x:40 instead of x:00 and x:30. Here's a pic just prior to striking the hour...
Pin A, small arm B, and brass collar C are all attached to arbor D. Small arm B drives pin A, which swivels loosely around arbor D until arm B contacts it.
One more pic, and then a hopefully clear question....
Should lever A, after being tripped by and falling off of pin A (as labeled in the previous pic), land on brass collar B in this pic, or on arbor C itself? If I bend that lever enough to get it to land on the arbor instead of the collar, the clock strikes as it should, but still 10 minutes too late.
Obviously, I don't completely understand this movement yet. Thanks for any help anyone's willing to offer.
wow
Jun 24, 2008
5,046
500
75
Pineville, La. (central La.)
B in your first photo is bent. The end of the half circle pushes the trip lever. Yours is bent so the center is pushing it. That is why it does not strike at the right time.
13,739
1,417
It will become more obvious when you get the clock apart. Ingraham had some odd contraptions on their 'set backwards' mechanisms.
A few weeks ago someone posted a close-up photo of one of these features, out of the case. Yours may not be exactly the same though.
MuseChaser
Feb 5, 2019
382
92
I've had it apart, Willie... Lol... Sure didn't show up on my bench that clean! I'm just not familiar enough (or smart enough?) to tell what's supposed to happen all of the time. Thanks for the suggestion re looking dor other pics. Here's what I needed to see...
RC and wow to the rescue
Thanks again, guys!
wow
Jun 24, 2008
5,046
500
75
Glad you found that thread, Muse. I also remembered seeing it but couldn’t find it. I remember the first time I saw one of those. I wonder how someone came up with the idea of inventing such a contraption:???:?
MuseChaser
Feb 5, 2019
382
92
I have no idea, but there's certainly no shortage of interesting, quirky, ingenious ideas in the clock world... so much fun.
Just wanted to stop back in to this thread and let you know that that was, indeed, the solution. Clock is now back together, looking nice and running nice. The face itself is pretty shot, and the thin brass moulding/bezel that is tack-soldered on and holds the face to the main bezel is a mess, but I managed to get everything mounted and lined up so it looks OK and and the arbors are centered enough in the openings to allow winding.
This is as she sits now. Three applications of Joel Warren's formula (twice w/ 0000 wool, then once with soft cotton cloth), one coat of Carnuba, and strip and polish of the brass bezel. Pretty little clock... an Ingraham "Colby."
165,381
1,439,448
86,183
Bluemax
2,873
