Ingraham clock keys
Discussion in 'General Clock Discussions' started by Organist, Jun 24, 2019.
  1. Organist
    Organist Registered User
    Aug 29, 2010
    204
    19
    Ohio
    Hi,
    I'm curious. Is there any particular reason why the only Ingraham style clock keys available are #6 when the Ingraham I have takes a #7?
    Thanks,
    Mike
  2. tracerjack
    tracerjack Registered User
    Jun 6, 2016
    1,128
    130
    Female
    Lodi, CA
    Just to be clear, American sized keys #6 and #7?
  3. rmarkowitz1_cee4a1
    Nov 26, 2009
    5,177
    869
    My son, that is one of the Great Mysteries of Life!
    RM
  4. Willie X
    Willie X Registered User
    12,774
    984
    Funny, everyone wants a clear cut defenative answer to there clock questions but in reality about all we can do from a distance is generalize.
    Like: the majority of American clocks use a #6 key. Some used a #4, 5 & 7. Quite a few will need something in between, or the winding square will need to be carefully dressed up a bit to use a slightly 'to tight' key.
    WIllie X
    Jim1970 and Time After Time like this.
  5. Uhralt
    Uhralt Registered User
    4,850
    575
    I noticed that frequently even keys that should fit according to the dimensions or the arbor square, in reality don't. Looking at the inside of the keys' square if found the there were residues from the broaching process or sometimes even incomplete broaching (too shallow). in these cases I used a square needle file to clean up the inside of the key until a had a perfect fit. Tedious but worth the effort.
  6. shutterbug
    43,465
    1,236
    If you buy the "make your own" key parts, you can come with one that works well. I've never found a way to get them nice and tight without solder though.
  7. Willie X
    12,774
    984
    FYI,
    Merritt's P-3 series of great American made keys has changed.
    They now have a slightly longer shank (which is good) but this is offset by a thinner wing with larger holes and sharp edges.
    These keys now come in a thin plastic wrapper and I suspect they are coming from China ... sad.
