I am working on an Ingraham banjo clock. It is running great. The problem is, it is running too good. It keeps time properly, but the suspension rod is hitting the sides of the throat just as it comes into the lower box. I have adjusted the verge to minimum locks and drops. The escape wheel just does land on the flat of verge, both entrance and exit palets. Would a thicker suspension spring do the trick? The rod it came with too short and not sure if the bob is even right.
Most visitors online was 1660 , on 12 Dec 2020
