Yes I have a Ingraham banjo clock that looses around 10 min of time a day Is there a way to speed it up Thanks Tim
Turn the rating nut on the bottom of the pendulum about 5 full turns and wait a couple of days. If the time does not change. Then I guess it's time for an overhaul and cleaning. I use a formula that I tell my customers. Every 360 degree turn on the rating nut, is about 2 minutes fast or slow, in a 24 hour period. Wait 5 days and divide the amount of time your clock is fast or slow into the days and that is how fast your clock is in one day. And then make the adjustment. Good luckYes I have a Ingraham banjo clock that looses around 10 min of time a day Is there a way to speed it up Thanks Tim
Thanks so much i will give it a tryTurn the rating nut on the bottom of the pendulum about 5 full turns and wait a couple of days. If the time does not change. Then I guess it's time for an overhaul and cleaning. I use a formula that I tell my customers. Every 360 degree turn on the rating nut, is about 2 minutes fast or slow, in a 24 hour period. Wait 5 days and divide the amount of time your clock is fast or slow into the days and that is how fast your clock is in one day. And then make the adjustment. Good luck
H/C
Is it fully wound when losing that amount of time?
