Hello!
I'm just finishing a ( hobbyist ) service on one of the 19J examples, and I would like to hear from anyone who encountered a problem similar to mine: it seems that the mainspring cap bushing is worn to a degree that stops the watch!
I have a new spring, and the watch may be wound about 1 1/2 turns...and that's it. At that point the winding becomes so difficult that it's dangerous to proceed. I took the barrel out, and noticed that there was a distinct ring of brass particles on the barrel arbor where it passes through the cap...and this, after just 2 or 3 winding cycles.
I'm thinking at this point that the arbor cannot run true once the spring acts upon it, and that the resulting tilt either causes the barrel to drag, or that the spring, itself, is pulled against the barrel with enough force to make winding impossible.
There are four teeth missing from the ratchet wheel, so I'm also assuming that this issue was around for some time.
I have another 16s Ingersoll-Trenton--a 17J--and it, too, is missing ratchet wheel teeth.
So: does it sound like my guess is correct? And, is this a known issue with these watches?
Oh: sounds like I'll need cap re-bushed...work I cannot do...anyone interested?!
As always: thanks everyone!
Michael.
Michael.
