That is an interesting watch. Your watch as the outward appearance of a verge escapement. However, the escapement wheel appears to have straight teeth. It could be that your watch is a Sully escapement (either original or converted). Robin invented his own escapement design, but this escapement appears to have a vertical layout. Could you provide additional photos of the escapement? Could you remove the balance bridge and take a photo, if you feel comfortable doing so?Earlier i show two repeaters in the complicated pocket watches section, this low serial numbered silver watch arrived to me with the repeaters together.
If i read the inscription good: Repassé par Robin, and the serial number is 5!
I welcome any new information from this watch.
View attachment 718335 View attachment 718336 View attachment 718337 View attachment 718338 View attachment 718339 View attachment 718340
"Repassage" appears so very often in the Louis Audemars books, also with the recorded names of the "repasseurs" of the "superior" quality products, that in my (fairly humble) opinion it had nothing to do with the eventual retailer.So it's not necessarily the retailer.
That's right, you won't see this in an English watch, it seems to be an exclusively French/Swiss mechanism. It allows the adjustments to be made without dismantling the movement; so much easier than the English way!I've seen english verge movements before, but I don't remember, that them having this adjustment mechanism
... The exact definition,
Repassé : Ultimate and complete mechanical and aesthetic control of an inserted watch just before it leaves the production workshops.
Just to keep the double discussion on-going"Repassage" appears so very often in the Louis Audemars books, also with the recorded names of the "repasseurs" of the "superior" quality products, that in my (fairly humble) opinion it had nothing to do with the eventual retailer.
Thank you very much.The main steps are 1 to 4, which are
1. making the ebauche,
2. finissage, i.e. completing the movement except for the escapement
3. plantage, i.e. mounting the escapement
4. repassage: "that consists of reviewing all the functions, posing the dial and inserting in the case" (sic).
The review was not just a quality control but it consisted in perfecting (re-working) the entire movement: for this reason it was given to very expert watchmakers in case high quality was wanted.
