Inconsistent hammer drop
Discussion in 'Clock Repair' started by bangster, Mar 20, 2017.
  1. bangster
    bangster Super Moderator
    16,331
    22
    I have this here Ingraham that I've just finished servicing, and it has an ailment: The strike hammer drop is inconsistent, randomly. Sometimes it hits the gong with a satisfying Bong!, sometimes a weak ding, most of the time it doesn't contact the gong at all.
    My theory is that it has to do with the way the hammer is activated by the lifting pins on the maintenance wheel...but I can't figure out how that could be. The hammer never fails to lift, but it only hits the gong randomly. I've tried the usual business of Bending Things, but it hasn't touched the problem.
    Before I go tearing this puppy apart again, I thought I'd ask y'all what you think might be going on.
    [​IMG]
  2. RJSoftware
    RJSoftware Registered User
    Apr 15, 2005
    7,668
    12
    Loxahatchee, Florida
    Well, I think your hammer spring needs adjustin Bong....!!
    (Sorry thought I'd imitate Scotty for a moment).
    but that is what I thinks.
    RJ
  3. bangster
    16,331
    22
    Thanks Arjay; hadn't thought of that.
  4. R. Croswell
    R. Croswell Registered User
    6,646
    24
    More than 'adjusting' I'm afraid. I believe this is the model that has just a short tail that hooks around the center post. Very easy to forget to hook it during assembly and a devil to hook after assembly. (been there done that)
  5. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    If the spring is there and tensed, you might look for the
    lever dragging on something. Since the levers are flat
    they can get bent towards or away from the front and back
    plates.
    You might be able to see such by looking from the sides or top.
    I think it is just the spring though.
  6. bangster
    16,331
    22
    HAH! Found it.
    Spring was okay, but hammer was loose on its arbor. A drop of Loctite fixed it. :clap:
    Thanks for the suggestions. You got me looking in the right area of the clock.
  7. ballistarius
    ballistarius Registered User
    Oct 26, 2009
    702
    Architect
    Bilbao, Basque Country
    Certainly, I cannot even imagine the hell it was clock repair before they invented Loctite...:whistle:
    Great you fixed that hammer at last:D
    Aitor
  8. R. Croswell
    6,646
    24
    Which Loctite product did you use? The shock loading of a hammer drop will be a real test for it.
Similar Threads - Inconsistent hammer drop Forum Date
adjust hammer heads Clock Repair Sep 13, 2017
Lubricating Hammer Pull Levers for Tubular Bells Clock Repair Sep 2, 2017
Newbie - time keeping inconsistent Clock Repair Jun 21, 2015
Inconsistent Time Keeping, Help! Clock Repair May 14, 2013
Ingraham Hammer Inconsistent Clock Repair Oct 26, 2012
