• Upcoming updates
$ Illinois Bunn Hunter - Burlington Watch Co
DaveyG
Mar 21, 2005
2,553
197
76
North Wales, UK
The Illinois Watch Database (Dr Snyder) indicates that there were only 100 of these 19 jewel Bunn Hunters made; one run in 1914. The gold fill case is marked with the Burlington mark and the dial is, apparently, of a style only used by Burlington. I am interested to know, are they really scarce and if so just how desirable would it be?
The watch is not in fabulous condition but it does set and run well; the case is quite worn although there is only brass on the bow and the dial has hairlines
richiec
Feb 24, 2007
7,198
924
69
Brick, Ocean, NJ
DeweyG, as far as I know, all Burlington watches came in Burlington cases with Burlington marked dials. I may be wrong but I think someone put a Bunn in a Burlington case. I am sure someone more informed than myself will chime in soon and give you an indication if it is original and worth anything more than a Bunn in a gold filled case.
Ron DeGenaro
Aug 22, 2013
251
7
Venetia PA
I believe the Bunn grade was sold as movement only. I would consider the watch you have to be very desirable for collectors as less than 300 were manufactured in the hunter style movement. I would estimate $500 as the low end of value.
Fred Hansen
Aug 18, 2002
5,494
865
Very tough watch to find and you are correct with 100 made. The movement plates look nice and bright with nothing too distracting in terms of marks and this is a big plus in favor of your watch.
Unusual dial to find and from memory I don't know if I've seen one marked Illinois that was exactly the same, particularly in the hunting case Model 8 version. Are the correct dial feet intact? No sign of the center chapter having been replaced (altered solder no the rear)? The reason I ask is that many of the hunting case Model 8 movements have dials with a missing or altered foot, or messed with center chapter, as they have one foot in a different position than the common open face models so there aren't enough good Model 8 dials to go around for the movements that need them.
Case is interesting with the Burlington markings, this does correspond with the dial numerals in the outer chapter which are a typical Burlington style, but I don't recall anything similar with a non-Burlington signed movement matched with this style dial/case so this is a bit of an oddity. In terms of value probably doesn't have much influence either way.
As far as value … I've seen a 19J 16s Bunn hunter bring as high as $4000, but this was in a stronger market and the watch had a very attractive and top condition dial/case. Today I might see your watch at potentially about half this level, so perhaps around $2000-ish to an IL collector that understands and wants it.
DaveyG
Mar 21, 2005
2,553
197
76
North Wales, UK
Thank you again Ron and Fred.
I can confirm that there are no alterations to the dial or dial feet. I suspected that the watch may be a bit of a scarce item when I bought it at an antique fair (mart) here in the UK, solely because it was a Bunn grade and a hunter, I didn't realise at the time just how scarce they are. Gratifying to know that I have bought at least one bargain in my collecting life :coolsign:
179,916
1,569,497
54,317
Eclectic Oddities
911
3,090
