Ignatz pendulum slipping
Discussion in 'Clock Repair' started by paddy2042, Mar 16, 2017.
  1. paddy2042
    paddy2042 Registered User
    Feb 6, 2017
    84
    I am the proud owner of a Ignatz flying pendulum clock that does not go. When I slightly move the pole the innards turn but they do not seem to be giving power to the arm to turn it. There seems to be no pressure on the arm at all in order to move it. Just wondering if anyone had any idea how to solve this without taking the thing apart. I believe it is a messy job removing the glued bezel and I'm sure I will damage the flimsy case.
    Patrick
  2. MartinM
    MartinM Registered User
    Jun 24, 2011
    2,316
    10
    El Dorado, CA
    Unless the arm is just not on far enough to engage the drive gear, it'll probably have to come apart. When you rotate the arm, manually do the hands advance or retard? If so, it's something prior to the final drive gear. If not, push downward lightly, while turning, on the arm to see if it can slide any lower on the shaft. You said the innards turn, so I assume all of that's okay. But, it's good to verify.
    You remove the top finial and then remove the arm to prepare the clock to come out of the case. The bezel glue isn't originally strong enough to hurt the case. If anyone's used something else to secure the bezel, all bets are off. You'll have to wind up the movement and pin it to stop it from unwinding in order to get the movement out. Be very careful of the long steel rod. That it doesn't get bent and that its staking to the clock frame doesn't become loose.
  3. shutterbug
    34,339
    30
    Everything has to be perfectly aligned in those things. Even a slight bend in the brass tube will hose it up. I'm also afraid you'll have to take it apart and rebuild it.
    - - - Updated - - -
    I might have some parts. PM me if you need some, and I'll look :)
  4. paddy2042
    Feb 6, 2017
    84
    I have taken the top finial off and the brass tube that turns the arm. The brass tube when turned manually does advance the hands so it looks like it is making contact.
    It is the flying arm that worries me. Should the arm be tightly clamped to the upright brass tube? On mine it is quite loose. I notice at the top of the brass tube there is a tiny flange with looks as though the arm may have been originally tightly attached. The arm ends in a loop which can be tightened. I'm wondering if I tighten it so the brass tube and arm move in unison without slipping whether that will make any difference.
    Patrick
  5. paddy2042
    Feb 6, 2017
    84
    I have been working on the clock and crimped the arm to the brass tube so there is no slipping and put the finial back on and the clock now seems to go. The thread is not quite catching on each side but I guess that is just a little adjustment that is needed.
    Patrick
  6. shutterbug
    34,339
    30
    You're close then. Keep fiddling. The ball has to be flying pretty fast to properly wrap around the wire catches.
  7. paddy2042
    Feb 6, 2017
    84
    I have enough trouble working on anything small especially clockworks, but this clock is so flimsy I am almost too frightened to touch it in case it breaks. It is a shame it was not produced with a bit more integrity and quality, as it is a really interesting clock.
    Patrick
  8. shutterbug
    34,339
    30
    It was always a novelty clock, designed after an earlier time control approach.
  9. MartinM
    Jun 24, 2011
    2,316
    10
    El Dorado, CA
    Try setting the top finial and arms so that the arms are a couple of degrees before the posts. This seems to make the action more consistent.
  10. paddy2042
    Feb 6, 2017
    84
    Thank you for that hint. I was wondering what the exact position of the bar should be in relation to the posts.
    Patrick
Similar Threads - Ignatz pendulum slipping Forum Date
Cleaning an Ignatz Flying Pendulum Clock Clock Repair Jul 14, 2014
ignatz flying pendulum clock Clock Repair Sep 23, 2009
Ignatz clock repair??? Clock Repair Aug 6, 2009
Ignatz Clock - Parts Source Clock Repair Jan 5, 2005
