I thought this would go best in the Clock Repair section. If a moderator doesn't approve of this post being in Clock Repair; I am sorry. I just thought this would be specific subject for the ones inclined for repairs/clockmaking.
Just to break up the monotony of all the subjects posted here. . . I think we should vent. I need to.
Most of my customers are great. Almost all of them are very agreeable, don't mind paying higher costs when I explain to them why it has to be higher, tip me on occasion, and are typically just awesome. I like my customers.
. . . But there are a few that have stuck with me, the bad ones, the ones I wonder why they even own a clock.
I started going to estate sales, leaving my cards in all the clocks. This always gets me good business, a lot of times within the same day. So this lady calls me and asks if I do clock repair, I sure do! She says 'I gotta mainspring you need to replace. CAN YOU DO THAT?!"
"Yes Mam, I sure can, no problem"
She then goes on to tell me she has the mainspring. She ordered it off eBay and it needs to go in the clock. I asked her if it was the right size, and she very loudly said "It's a MAINSPRING!."
I'm starting to get irritated.
I explained to her that there's hundreds of different mainsprings. She barely understood. I then asked her what type of clock it was. She said it's an old gingerbread type clock. I told her that with that type of movement, it'll need a disassembly to replace that spring, and that takes time. She asked what that would cost, and I told her "Well, I need to see the clock to give you something more exact, but as long as you have the right size mainspring, it'll probably be about $60-$70, maybe less, depending on how easy that thing is to get apart and back together."
"Well I think $20 is fair!"
I then explained to her that there is no way in hell I was going to replace that spring for $20. Finally, she agreed that $60 would be fine. Then she pulls out more demands.
"And you're gonna guarantee that clock is gonna run?"
Now I'm furious. This woman is a complete moron. She's a tightwad, she's rude, and she wants me to put my name behind crappy work, dictated by her. My response:
"No mam, I will not guarantee it. If you want my guarantee, you're gonna let me disassemble that movement, replace both springs, clean it 100%, rebush it, polish pivots, reassemble, and regulate it."
"WHAT'S THAT GONNA COST?"
"For you? About $250."
"I don't think so"
So I then refer her to my competitor. I informed her that his backlog is about 16 months, she is now pissed off, and hangs up on me.
One more story:
I'm out with my wife at a restaurant attached to the lobby of a hotel. I see a beautiful regulator hanging up on the wall, not running. After eating, I go to the receptionist and asked her about that clock. She says the owner wants it fixed. I give her my card, and she excitedly calls her boss over to the front desk. I explained to him that I repair clocks, and that I'd like to look at it for him. He asks how much, and I told him that since I'm already there, I won't charge a service call fee, I'll just take the movement back to my shop and look it over. I told him I'd look at it for a $10 diagnosis fee, plus whatever it takes to fix it. He said "Okay! Sounds Great!" He then shows me what he thinks is wrong with it. I cannot remember exactly what was wrong, but what was obvious was a lever that was bent out of place because someone messed with this movement while inside the case. I told him I'd reset that lever and see if it would run.
I get home, I fiddled with the lever for 5 minutes (I can't remember what lever it was, or why it was stopping the clock; I just remember it wasn't a big deal, just user error, no true damage). I also noticed that the movement was dirty, typical dirty, black grime around the pivots, little bit of dust here and there, a few worn bushings, nothing huge, just dirty, and typically worn; very typical. When I hung it up, it would not run. It was very obvious that this was a loss of power, and needed a servicing.
The next day, I was going by that hotel, so I brought the movement with me, and went back to show him what was going on with it. I get there, explained to him that I reset (or rebent) that lever that was jacked up, and it still wouldn't run. He acted confused. I showed him the grime, the wear on it, etc. He was flabbergasted. He looked at me like I shot his dog. He asked how much, I explained to him that since it was a two train, and fairly simple, it could be around $170-$200 or so, a little more or a little less. He then says "NO! That's not why it's not running. It's NOT dirty."
I'm immediately angry. My response:
"Oh. I didn't know you worked on clocks. I'm glad you figured it out."
He couldn't believe I was talking to him like this. His eyes got big, I don't think he has been talked to like that, since he was the hotel owner, used to people fearing him. My opinion.
I then said "So. You want me to reinstall this movement?"
"... Yes"
So I go and reinstall the movement. I hang the pendulum. I hang the weights. I go around the front to write his receipt. As I'm writing this receipt, this moron goes and opens the case, and starts flicking the pendulum. Then he reaches up and grabs the movement mounting screws, starts unscrewing it, and tears that movement out, bending the exact same lever that was bent in the first place.
He looks it over, sees that lever out of place, and then brings it to me.
"Alright. You need to fix that."
"No. I already fixed that. You just broke it. Again. You need to fix that."
Now I think he realized he is stuck with a broken clock.
"Alright. How do I get this fixed?"
I then referred him to my same competitor, gave him the exact same "He has a 16 month backup. Good luck" advice. I even pulled my phone out, and got his phone number for him. Finally, I tore the receipt and said "That'll be $10" I got my money and left.
About 8 months later, I go back to the restaurant, and there's that clock. Not running. I guess he really likes it not running.
"I don't think so"
One more story:
"... Yes"
