Identifying maker: “Gruen” signed 11.25L pin set movement
Discussion in 'European & Other Pocket Watches' started by mosesgodfrey, Sep 17, 2019.
  1. mosesgodfrey
    mosesgodfrey Newbie
    Aug 30, 2017
    22
    Seeking help to identify the maker of this movement & approximate date of make—simply signed “Gruen”, although I’ve not seen another Gruen quite like it. Winding mechanism looks like some LeCoultre movements I’ve seen, but looking for a more experienced eye.
    11.25L, pin set at 1 o’clock position. Open face configuration. Back of dial hand marked “S5”. Dial side of movement has small stamped 6 digit sn, large stamped 5 digit sn, and two tiny hand marked #s (“10” or “01”) near pin. Seems to be a mark between the bridges near the balance wheel, but cannot clearly ID it or get a clear pic.
    Thanks!
    8069D328-6D2E-453A-8316-6D6B7E7FA8E8.jpeg 1F9B4E71-9619-4351-9DBF-90EE6E80901A.jpeg
  2. Steven Thornberry
    Jan 15, 2004
    21,132
    711
    Ne’er do well
    Here and there
    Maybe it's just my general unfamiliarity with such watches, but the word "Gruen" gives me the impression that it was added post production.
  3. Audemars
    Audemars Registered User
    NAWCC Member Sponsor
    Aug 6, 2010
    1,012
    79
    Somerset, UK
    Well, this is a very long shot.
    I have a few archive references to Gruen as a Louis Audemars customer .
    There is a 12990, shipped in December 1882 to J Eugene Robert, the LA distributors in USA.
    It was a hunter movement (strike one against it! - although I have had a few instances where they got their records wrong), 18 lignes, anchor escapement, shipped without a case,
    Cost 360 francs, discounted to 270 in lieu of commission (25% - wow!).
    Paul
  4. Ethan Lipsig
    Ethan Lipsig Registered User
    NAWCC Gold Member
    Jan 8, 2006
    1,838
    669
    80% Retired Attorney
    Pasadena
    C.H. Meylan used substantially the same movement in a few watches. It is the uncommon Type G in my personal classification scheme. See Dropbox - C.H. Meylan Serial Number Database.doc - Simplify your life
    This does not mean the C.H. Meylan made the movement. It is as likely that the movement or its ebauche was made by a third party that supplied both Meylan and Gruen. I see some minor finishing differences. e.g., around the regulator, between the two watches..
    z heptagon Meylan.jpg IMG_5261_edited.JPG IMG_5263.JPG IMG_5265_edited.JPG IMG_6208_edited.JPG
  5. mosesgodfrey
    mosesgodfrey Newbie
    Aug 30, 2017
    22
    Thanks, Ethan. Meylan is a good bet. Haven’t considered them. I have seen early Gruen signed movements confirmed as theirs before. The mark in the bridges from what I can tell does look like a fancy scroll “M”. Will check mikrolisk to see if there is one similar to what I’m seeing.
  6. mosesgodfrey
    mosesgodfrey Newbie
    Aug 30, 2017
    22
    Btw, Ethan, I note the 6 digit sn on dial side of your example, matching font & placement as mine, which would I assume be from the ebauche supplier.
    I also see what looks like a tiny mark between bridges on yours, similar placement as mine. Any chance you noted what that was?
  7. Ethan Lipsig
    NAWCC Gold Member
    Jan 8, 2006
    1,838
    669
    Pasadena
    Sorry, I do not have my Meylan at home. The photos I have of it do not show the mark well enough. It will be a while before I go to my bank again, but when I do, I will take a look at the watch.
  8. Barney Green
    Barney Green Registered User
    Jan 19, 2017
    electronics engineer
    Diesel gate HQ
    I am currently looking deeper into the earlier Swiss companies which supplied movements to Gruen.
    This movement has some details which I believe would fit to FHF as ebauche maker. Unfortunately I am currently away from home so that I cannot crosscheck my sources, but will be able to do so during the weekend.
    Barney
  9. mosesgodfrey
    mosesgodfrey Newbie
    Aug 30, 2017
    22
    Thanks, all.
    Ethan--I finally had a chance to review your document in detail. That is some fine sleuthing! Appreciate the opportunity to gain this knowledge, whether it turns out this is/is not a Meylan. Thanks for sharing it.
  10. Ethan Lipsig
    NAWCC Gold Member
    Jan 8, 2006
    1,838
    669
    Pasadena
    Thanks for the kind words.
  11. Jack_W
    Jack_W Registered User
    Mar 8, 2010
    156
    Geologist
    Wheat Ridge, CO
    #11 Jack_W, Sep 20, 2019
    I've one of these movements. Have posted about it on the WUS forum.... Gruen cal. 98 and Swiss Patent 51482
    It is certainly a match to the Type G in Ethan's data.
    The detent screw location is a clue:
    One thing is that the underside of the barrel bridge, it is stamped 'Rannaz'. Which was an ebauche maker. Beyond that no clues.
    pictures are not the greatest, I know.... serials are
    133360
    12973 which is next to the cap jewel on the top plate (dial side).
    Marked Gruen on the center finger bridge.
    No other markings.
  12. mosesgodfrey
    mosesgodfrey Newbie
    Aug 30, 2017
    22
    Thanks, Jack. Yours is very close in numbers to mine: 12,990 & 133,365.
    A good lead on Rannaz as the probable ebauche maker. I plan to have my watchmaker check to see if there’s a matching stamp on my movement.
    Jack_W likes this.
