Identifying granddaughter clock
Discussion in 'General Questions' started by dw2007uk, Mar 16, 2017.
  1. dw2007uk
    dw2007uk Registered User
    Dec 2, 2007
    34
    Hi
    Can anyone please give a rough guide as to the date and maker of this granddaughter clock?
    It's 5ft tall and has Whittington and Westminster chimes. Unfortunately I can't see any reference to its maker or place of manufacture on the dial, case or movement.
    Thanks!
    [​IMG][​IMG]
    [​IMG][​IMG]
    Attached Files: Download all post attachments
  2. chimeclockfan
    chimeclockfan Registered User
    Dec 21, 2006
    3,343
    12
    This one looks like a pre-war Urgos movement. The same base movement was used for mantel clocks.
    The case was probably British made. Your clock was most likely made during the 1930s.
  3. dw2007uk
    Dec 2, 2007
    34
    Thanks for the info! :)
Similar Threads - Identifying granddaughter clock Forum Date
Help identifying this clock General Questions Mar 10, 2017
Help to identify an ansonia clock General Questions Mar 9, 2017
help identifying movement General Questions Mar 6, 2017
Help identifying Gustav Becker movement General Questions Mar 6, 2017
Jas. Spondlow Brandon granddaughter clock General Questions Sep 3, 2016
