The closest Assay Office to Coventry is obviously Birmingham. While it is true that for gold wares, including watch cases, there was a 'prestige preference' for London, then Chester, before Birmingham, prestige was not the only factor. As a gold case maker, Yardley registered at both London and Chester. The fact that he did not register in Birmingham is no doubt a reflection that he focused on gold work.If you're wondering about a Coventry case maker registering their marks in the London assay office, they did also have registrations in the geographically closer Chester office, but the London mark carried more prestige at the time. Coventry has never had an assay office.
Thanks so muchWelcome to the forum.
The 18K gold case in your photographs was made in Coventry by Richard Yardley of 132, Spon Street. His mark (RY) in an oval cartouche, was registered at the London Assay Office on three consecutive occasions, the last being 17 June, 1873, which is the one pertaining to your case. The London hall marks include the date letter 'A' that was used between May1876 and may 1877.
Richard Yardley was previously working with William Buckland between 1.1.1868 and 25.10.1869, registered as gold case makers. Yardley continued to work in Spon Street after the partnership was dissolved.
If you post photographs of the watch face and movement we can provide more information.
John
Thanks I’ll upload some pictures asapI suspect that the front cover is hinged, even if it's an open face movement (pendant/bow at 12:00.), which I suspect it is. I may even see a protrusion/lip just below the pendant on the rear image. If so, that would be the pry point to open up the front. Then, as roughbarked said, you'll find that the movement is hinged into the case from the front. There should be some sort of release tab visible, probably at the 6:00 position, that you pull up with a fingernail. Still, before you go prying and releasing, it would be nice to see the front of the watch, especially with the bezel hinged open. Good luck.
ThanksHi Nasman,
Just to clarify, the case maker wasn't necessarily involved with the making of the movement, in fact in the majority of instances they weren't.
