Identify MANUFACTURER of SWISS Private Label Movement
Discussion in 'European & Other Pocket Watches' started by timeless1, May 10, 2018.
  1. timeless1
    timeless1 Registered User
    Feb 28, 2012
    32
    Hi,
    I would very much appreciate any help in identifying the MANUFACTURER of this 'Private Label' Swiss pocket watch movement. The name on the dial and rear of the movement is "CHAPMAN & ARMSTRONG". The writing on the rear of the movement is "CHAPMAN & ARMSTRONG, GALESBURG, ILL, ADJUSTED, 24446, SWISS". The movement measures 41.85mm, it is lever set (with a straight pull-out arm), has wolf teeth winding gears, gold balance screws, is 21 jewels, has a square winding post at the 3 o'clock position and a 'cam' style regulator.
    upload_2018-5-9_21-28-23.jpeg upload_2018-5-9_21-28-23.jpeg upload_2018-5-9_21-28-23.jpeg
  2. astonvilla
    astonvilla Registered User
    Jun 3, 2001
    243
    Jules Monard - Geneve
  3. rrwatch
    rrwatch Registered User
    Gibbs Literary Award NAWCC Fellow NAWCC Member
    Sep 4, 2000
    1,430
    272
    Watchmaker
    Pooler, GA USA
    Here a some photos of a "Jules Monard" marked movement, very similar to yours, except for the lack of Wolf's tooth winding gears.
    Monard, Jules EBU 16287, SN 23,834 Back Cover.jpg Monard, Jules EBU 16287, SN 23,834 Cuvette.jpg Monard, Jules EBU 16287, SN 23,834 Dlal & Bezel.jpg Monard, Jules EBU 16287, SN 23,834 Front Cover.jpg Monard, Jules EBU 16287, SN 23,834 Inside Rear Cover.jpg Monard, Jules EBU 16287, SN 23,834 Mvt.jpg
  4. timeless1
    Feb 28, 2012
    32
    Thank you very much for your time, very much appreciated! You have a beautiful watch...thank you for sharing it!
