Identify Country of Manufacture and AGE of this key wind CLOCK CASE???
Discussion in 'General Clock Discussions' started by timeless1, Apr 14, 2019.
  1. timeless1
    timeless1 Registered User
    Feb 28, 2012
    32
    Hi,
    I would very much appreciate any help in identifying the Country of Manufacture and AGE of this CLOCK CASE and how it was used?? It has a fixed bow on the top and I presumed it hung from a clock statue?? This case was found at a 1960's watch and clock repairman's estate.
    Brass case dimensions are 78mm max diameter and 28mm max height. Looking at the rear of the case there is a slight remnant of a gold gilt finish. There is a sliding cover / hatch retained by a rivet that covers the key wind hole. The upper bezel is press fit. The hand painted enamel dial is mounted to a brass plate; perhaps the symbols at the 3, 6, 9 and 12 are fleur-de-lis, French?? Interesting, there is a small hole centered under the bow in the side of the case. There are 3 very small holes in the side of the case at the 1, 5 and 9 o'clock positions, presumed for mounting the movement with small screws.
    Thanks for looking!!
    1S67dvuQR%Gqoez546CTJA_thumb_3d70.jpg 3BkkaUeKR3CqIg1kBGsNBA_thumb_3d6e.jpg 4x51W5adTDKRdtQhAepD+Q_thumb_3d75.jpg 9SALDhFZTsW3ilHL9KNLDw_thumb_3d76.jpg G6XY7bToSV+gFW5f9T6yOg_thumb_3d74.jpg g8cV1HLWTEu3mCT42fI2vA_thumb_3d73.jpg oI8A8bVAQHmrjf%mwY4oJg_thumb_3d72.jpg qusxmh04T%SFiIMS8997qQ_thumb_3d6d.jpg SGzBaNwZQ5CJEhAGnP9kIQ_thumb_3d6f.jpg SnJuqEr%SAe0Miu4vgLC4A_thumb_3d71.jpg yNjOAnE8RJme8UTQYkWl9w_thumb_3d77.jpg
