French Identify Age & Manufacturer of this French ? Calendar Clock
Discussion in 'General Clock Discussions' started by timeless1, Nov 15, 2018.
  1. timeless1
    timeless1 Registered User
    Feb 28, 2012
    32
    Hi,
    I would very much appreciate any help in identifying the MANUFACTURER / AGE of this presumed French made calendar clock. The clock movement has the serial number, "4892", with NO visible manufacturer marking on the rear plate. The calendar movement has the serial number "1058" and has a presumed manufacturer marking on the rear plate of "C.R" inside a horizontal double oval.
    The name on the dial is "J. T. MACKAY"; I found a listing for "J. T. Mackay & Son, jewellers" in an 1871-1872 Scottish post office directory, perhaps this was the retailer?
    On a full wind the clock ran for 15 days; are there 14 day mainsprings or would it most likely be a 30-day mainspring that needs cleaning?
    Thank you for any information that you can provide.
    5phIatudTZ+35TmMtHO6jw_thumb_381f.jpg hg9W1OpUQHGqqXQmYxUhmg_thumb_3824.jpg Oiw7ZvFgTsm9y2F8oaYJBA_thumb_3827.jpg %x4tD+9+QPiUanIOpiE0Tw_thumb_3826.jpg zc0AnCFJTOSjFufAJ5JBRQ_thumb_37e6.jpg TmW2+OaoREahmIaQJtyrMQ_thumb_37e7.jpg 2fw7LGI8QPa0Nz99zpy+Ng_thumb_37e9.jpg
  2. bruce linde
    bruce linde Technical Admin
    6,726
    805
    oakland, ca.
    nice clock... why wouldn’t it be a 15-day clock? i have several (although no frenchies)
  3. Steven Thornberry
    Jan 15, 2004
    22,079
    1,027
    Ne’er do well
    Here and there
    #3 Steven Thornberry, Nov 15, 2018
    I would agree that the clock is French.
    The name MacKay is probably, as you suggest, a retailer, quite possibly the same firm you mention.
    A fifteen-day run is quite likely, but I suspect it is probably not a 30-day runner.
    The initials C.R (or is it G.R.?) may be those of a finisseur, or finisher, of the movements, or possibly the maker of the calendar movement (?).
    All in all, a nice looking clock.
  4. timeless1
    Feb 28, 2012
    32
    Hi,
    Thank you very much for the information you have provided.
  5. zedric
    zedric Registered User
    Aug 8, 2012
    1,187
    164
    This style of clock was pioneered by Brocot and Delletrez in the mid 1900s. It’s certainly French, but I don’t know who CB is..
  6. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    4,737
    131
    Devon
    Nice French marble clock probably last quarter of 19th C. Afaik it is not uncommon for these pendule de Paris movements to run for 2 weeks, I have a couple that do, whereas 30 day ones are. No idea who CR is but if he was responsible for both you'd have expected the clock movement to also be marked.
  7. gmorse
    gmorse Registered User
    11,375
    1,646
    Retired from Xerox
    Hi timeless1,
    This does look very much like the perpetual calendar invented by Achille Brocot, with its clouds and blue sky. Not that common and quite sought after, especially with a case in good condition like yours. These larger size French round movements often do have a fortnight duration.
  8. janekp
    janekp Registered User
    May 21, 2011
    102
    Nice French clock with L A Brocot Calender brevette
    http://www.nawcc69.org/pdf/Brocots_v3.pdf
    Patent nr:
    05275 1847-03-23 Louis-Achille Achille Pendulums Pendulums
    05275 1849-05-22 Louis-Achille Calendar
    05275 1852-04-06 Louis-Achille Calendar and escapements
    05275 1853-10-05 Louis-Achille Center seconds and alarm
    12482 1851-10-08 Louis-Achille Calendar
    50982 1861-08-28 Louis-Achille Calendar and escapements
    69234 1865-10-19 Louis-Achille Achille Calendar
  9. timeless1
    Feb 28, 2012
    32
    Thank you all very much for your information and the slide presentation is excellent!
