Most visitors online was 1660 , on 12 Dec 2020
They could have been scribed by a depthing gauge in preparation for rebushing. The idea is that you use the depthing gauge to find the precise gap between the pivot holes on the plate where the hole is not worn, i.e. if the worn pivot hole is on the back plate then you use the front plate and vice versa, of course if the pivot hole is worn on both plates this procedure will not work. You set the gauge to the gap between the mate of the worn hole and another nearby hole then keeping the gauge fixed at this gap you move to the plate with the worn hole and place one of the runners in the same nearby non worn hole and use the other runner to scribe an arc across the worn pivot hole. You repeat this process with another nearby hole so that you end up with two arc criss-crossed across the worn pivot hole and this should be where the centre of the worn hole was. I know it sounds complicated but I saw it being demonstrated by an experienced clockmaker and it really does work. I'm not sure if it is better or faster than using a centering punch or just a visual determination of where the center should be.
Good to know the clockmaker does it right. My dad worked on clocks in the 60’s and 70’s. He was taught that way and did it until he was able to get a hand bushing tool. Once he learned how to bush with the tool, he quit punching. I get punched movements often. Most of the time I am able to hide the punch marks with the new bushing.Punching to close up pivot holes was an accepted practice once. Did those semi circular punches exist for anything else, I don't know? I've seen them done all round making a flower pattern.
I think it is something that has been done for centuries.
I have encountered punch marks on several of the clocks I’ve worked on; some looked amateurish, while others were well-placed and seemed to accomplish the intended purpose. I had always assumed that bushing pivot holes was a fairly recent(1960s or later)repair method, and that these earlier clock repair people just used the methods that were available and accepted at the time. After reading all of the criticisms here, I have to ask...how long have pivot bushings been in the mainstream of clock repair? I used “mainstream“ to avoid replies saying the earliest known use was when Grog the caveman whittled a hickory bushing for his rock clock in 900BC...This procedure is very unprofessional. It is done to avoid disassembling the movement and doing it right. If an experienced clockmaker does this, he is doing shotty work. That movement in the photo should be disassembled, punch marks repaired, thoroughly cleaned, bushings installed, pivots polished, and everything else inspected and repaired if needed. IMHO.
